Actual Towing Limits...
#41
I'm sure not trying to be part of a gang jumping on you man, but you can bet your *** those trucks are built to last more than 2 days past warranty. They design the truck/warranty package so that only the extreme outliers (statistically speaking) will wind up needing major power train work before warranty is up. To accomplish that you need a product that will 999 times out of 1000 last well past the warranty period even when used to maximum capacity.
Design a product, then warranty it until right around the time you actually expect it to crap out and you'll find yourself making major repairs to about half of what you sell.
***EDIT***
That's right.......................... I pulled a thread out of the dark ages, at least you know I was using search
***EDIT***
I have been in the tire/repair business for over 10 years now and regularly see heavy and over loaded pick up trucks. We have put plenty of transitions, spring hangers, and other parts on trucks due to the excessive weight. Often it is the same guys with the same trucks getting the same things replaced. Like you said the "factory rating" is given with a large air of caution so that the dealers aren't constantly replacing parts.
Now to answer the modified question of the OP a truck can damn near pull anything you put behind it. I live where it is flat so hills and mountains don't play any roll around hear. My 1500 Tahoe has had around 12,000 behind it and did a great job. It certainly could do more but it was a one time thing. Pulled the load to and from a house to use the equipment. I am sure if I put 12,000 behind on a regular basis the truck wouldn't last too long but I am not sure the factory ratting on my truck to be honest.
calsdad
Jun 14, 2023 11:07 PM
