2002 Duramax
Old Nov 9, 2008 | 05:44 PM
overkill 19's Avatar
Default 2002 Duramax
My 2002 duramax dropped a rod @ 220 000KM. Can I put a 05 in it? What else might I need?
Old Nov 12, 2008 | 05:03 PM
sdimer350's Avatar
Thumbs up
as long as you use your turbo. 05 was the first year of the lly, which is just a lb7 (what u have) with a VVT. Or you could do this http://www.socaldiesel.com/SoCal%20D...oker%20Kit.htm
Old Nov 12, 2008 | 11:58 PM
A_T_Ver's Avatar
Might as well build it. But look here http://www.duramaxdiesels.com/forum/...ead.php?t=8064
Old Nov 16, 2008 | 06:48 AM
Thanks, found complete truck with 30000KM, for $6000 front Pass side smashed. If all I have to do is run my turbo thats will work. I though I would have to change out the harness and computer.
Old Dec 1, 2008 | 02:00 PM
mainer's Avatar
also need to run your heads. as the lly's use different injectors and your lb7 injectors wont fit in the lly heads etc.
calsdad
Jun 14, 2023 11:07 PM
$A_Money$81
Mar 27, 2023 10:25 AM
Avalanche2002
Nov 30, 2015 07:31 AM
The_W
Oct 1, 2015 02:35 PM
La Grey 1
Sep 21, 2015 11:07 AM
