1500HD Tooley cam choice help
Old Oct 30, 2015 | 09:17 PM
Bdanielshd's Avatar
Default 1500HD Tooley cam choice help
I am rebuilding my lq4 for my 05 4x4 1500HD. Going .30 over with flat tops, 243 heads, tooley dual spring kit with titanium retainers (because I got a great deal) speed enginerring long tubes no cats truck has 3.73 gears now and I will upgrade to 4.30 at some point and am open to new torque converter, I want truck to be fast overall I will probably tow maybe 6k in future torn between these two cams. Input is greatly appreciated
BTR truck stage 3.. Specs are 218/224 .553/.553 113+3
BTR truck stage 2..
Specs are 212/218 .553/.553 113+2
Old Oct 30, 2015 | 10:31 PM
TXsilverado's Avatar
either would work great. I'd probably go with the 212/218 but bring the LSA down to shift the power lower. 4x4 HD is not a light truck to push around. the 212/218 is known to be a stump puller in the 6.0.
Old Nov 2, 2015 | 01:46 PM
Bdanielshd's Avatar
Thanks TX anyone else
Old Nov 2, 2015 | 01:52 PM
Vortec350ss's Avatar
While I agree with Stew, the stage 3 isnt exactly a huge cam either. A 218 lobe on a 110 ICL should have plenty of pop.
The stage 3 will be faster, but the stage 2 will make a little more steam at part throttle down low and towing.
Old Nov 2, 2015 | 03:30 PM
110 ICL? I was thinking 110 LSA with 106 ICL
Old Nov 22, 2015 | 06:58 AM
madmann26's Avatar
I've got a 216/224 in my 372. It's on a 114 LSA and the ICL is 110.
It chops a little and pulls really really good off idle.
Old Nov 23, 2015 | 07:27 AM
11MPG's Avatar
Yeah 110 LSA in something that tows is awesome. In a 6.0 I would so go as big as a Texas Speed 220/220 with a 110 LSA. By as low as 2,500 rpms you'd surpass the torque of the stock 6.0 cam.
Old Nov 23, 2015 | 11:14 AM
Bdanielshd's Avatar
madman what truck do you have that in and are you running a converter?
Old Nov 23, 2015 | 11:40 AM
madmann26's Avatar
It's in 2006 ECSB 2wd. I have 410s and a loose Circle D 3200 stall.
Keng
Oct 27, 2015 12:14 AM
KleanKustoms
Oct 14, 2015 09:50 PM
thundurchasur
Oct 9, 2015 08:26 AM
carid
Oct 2, 2015 09:33 AM
