Sponsor's Announcements, Sales, and Specials This is for our site sponsors to make announcements
Introducing DashLogic Display Controller
Old 07-14-2014, 12:03 PM
Seanh's Avatar
Originally Posted by PalmerPerformance
Add any aftermarket sensor eg. Wideband, Methanol Pump cycle, EGT, Temp sensors, etc.
Great list, what is needed for aftermarket?
For instance, I'd like AFR, Boost, EGT, Fuel pressure.
Old 07-14-2014, 02:55 PM
FormerVendor
PalmerPerformance's Avatar
Originally Posted by Choda
So u plug it into the obd2 port and it updates the stock gauge w all those things u listed? Am I missing something or is it really that easy? How do you switch between pages? Does it stay on with the truck off, do you have to unplug it?
Yes you just plug it in. You use the door lock button to change pages. You can use our Windows configuration tool to make the layout however you would like it to look, then plug it back in.
Old 07-14-2014, 02:58 PM
FormerVendor
We can get boost from the GM MAP sensor. You would need a 2 bar or greater MAP, otherwise it will peg the sensor. We can do 2 analog inputs. I would use AFR and Fuel Pressure if it was me. You can also set alerts to those as well, so if fuel pressure drops under full load it would chime a noise in the vehicle, or if AFR goes higher than a number you set at full throttle then you would get a chime and notification on the display.
Old 07-14-2014, 08:48 PM
chewbaccav8's Avatar
Wow, those are really nice. I would like to see something for 2004 year models also.
Old 07-30-2014, 11:29 AM
FormerVendor
We are still looking into the options for reprogramming the display or finding another mode for text. It only allows us to update about once per second and it has to go black before it will put up new text.
Old 07-30-2014, 03:00 PM
KickinAssAndTakinNames
colekill's Avatar
thats pretty cool you got it to go through the dash.
I bought one of these about 4 months ago. pretty much the same thing but you have to mount it.
Linear-Logic/ScanGaugeII with trip data computer, real-time display of operating conditions and scan tool (SG2) | ScanGauge | AutoZone.com
looks like it has some parameters you don't and you have some parameters it doesn't.
Old 07-30-2014, 03:46 PM
Choda's Avatar
I really like this
Old 02-22-2015, 05:58 PM
bigsapper's Avatar
Are you guys working on one for the K2x series?
Old 04-26-2016, 09:49 PM
mikeskiw's Avatar
Default Dash Command
Can you start a thread for Dash Command? I am using you application in my supercharged 2007 Avalanche. I have modified the gauges in the basic dashboard to display boost and trans temps. I would like to display some other parameters like fuel pressure, exhaust temp, air fuel mix (actual not just command), maybe a few other things too? The system has tons of information available. I just setup dash mount for my iPad mini so I can see things better. Using a $20 obd2 to wifi to your app it's an amazing deal for access to so much info. I did purchase the extended parameters package for another $10 but I'm still not reading Lamda or fuel pressure? I'm also using it in my Ford Fushion company car to track mileage. It's very powerful and informative in that vehicle too.
Avalanche2002
11-30-2015 07:31 AM
turbo6c3
10-05-2015 06:11 PM
old motorhead
09-29-2015 08:22 PM
Quick Reply: Introducing DashLogic Display Controller
