Introducing DashLogic Display Controller
DashLogic is the most advanced way of displaying vehicle data to date. There is nothing to install, no programing, no changes to your vehicle in any way. Simply plug in the DashLogic device to your vehicles OBD-II port and DashLogic turns your factory dashboard display into a fully customizable gauge canvas. See all of the data your vehicle has to offer on your Driver Information Center. DashLogic doesn't stop there, you can also customize visual and audible alerts that you set to any condition for any vehicle value, fully customizable by you. Just in case your car doesn't have a sensor for a value you would like to watch, DashLogic also has two auxiliary inputs so you can add up to two aftermarket sensors to be viewed on your DIC as well as be used for alerts. The DashLogic alerts system is a very advanced tool, this is not your run of the mill type of simple alert that only watches one value. DashLogic will take into account several conditions for one alert, all of those conditions fully customizable by you. DashLogic also tests your performance, use DashLogic to get your calculated HP & TQ, 0-60 time as well as your 1/8th mile, 1/4 mile, 1/2 mile, and standing 1 mile times recorded with a trap speed.
Quick video of the display
https://www.youtube.com/watch?v=Eez7...ature=youtu.be
DashLogic is now available for
2005-2013 Corvette
2010-2014 Camaro
2007-2013 GM Truck and SUV (gas and diesel)
2005-2010 Cobalt
2010-2014 Cruze
PPE Online Store
Thank You
2005-2013 Corvette
2010-2014 Camaro
2005-2010 Cobalt
2010-2014 Cruze
PPE Online Store
Thank You
Horsepower and Torque
0-60 time
60-130 time
1/8, 1/4, 1/2, Standing Mile with trap speed
Fuel flow rate
AFM Active
Distance with AFM Active
VVT position
Load
Coolant Temp
Short term fuel
Long term fuel
Manifold pressure
RPM
VSS
Spark
Intake Temp
Mass Air
Throttle Position %
O2 sensor volts
Fuel Level
Baro pressure
Loop status
Fuel Alcohol Content (HPTuners PID)
Commanded EVAP
Commanded Lambda
Ambient air temp
Knock Retard
Oil Pressure
Oil Temperature
Injector Pulse Width
Total Misfires
CMP RPM
CKP RPM
Delivered TQ
Fuel trim cell
Torque Management Spark Retard
Power Enrichment Active/inactive
Electronic pedal position
Current Gear Position
Trans Fluid Temp
Average vehicle speed
Fuel Range
Average Fuel economy
Instant Fuel economy
ABS Wheel speeds
Steering Wheel Angle
Brakes On/Off
Tire Pressures
Boost/Vacuum display
Vehicle Voltage
Add any aftermarket sensor eg. Wideband, Methanol Pump cycle, EGT, Temp sensors, etc.
Create your own calculation PIDs to what you choose
User set Alerts for Audible and Visual warnings for any data you choose or calculation of data
0-60 time
60-130 time
Fuel flow rate
AFM Active
VVT position
Load
Coolant Temp
Short term fuel
Long term fuel
Manifold pressure
RPM
VSS
Spark
Intake Temp
Mass Air
Throttle Position %
O2 sensor volts
Fuel Level
Baro pressure
Loop status
Commanded EVAP
Commanded Lambda
Ambient air temp
Knock Retard
Oil Pressure
Oil Temperature
Total Misfires
CMP RPM
CKP RPM
Delivered TQ
Fuel trim cell
Trans Fluid Temp
Fuel Range
ABS Wheel speeds
Brakes On/Off
Tire Pressures
Vehicle Voltage
If this is Cody, just wanted to say thanks for your help the past couple of days, and if its not Cody, still a big thumbs up for palmer performance products and there customer service! Cant wait to get your product its what I've been looking for. THANKS GUYS!
