B-day, Turbo kit special, New 1800.00 kit..
Special on turbo kits. We need 5 customers to make this killer deal happen.
These non-inter cooled kits are very good enter level boost applications. Inter-cooler upgrades are available for 650.00. Our inter-cooler kits have the shortest aluminum pipe routing in the industry. Can be maf or maf-less.
Comes with bead rolled ends, standard.
Prices + freight and or fees.
PM me if I can help you get into boost, or if you have any questions.
Rick
You have 3 options as far as the kits go.
Standard, Mandrel, and Stainless.
Standard: 1800.00
Years 99-11 trucks,
MP70MM turbos,
Swept runner thick wall manifold
38mm gate, vented to atmosphere
44mm blow offs,
oil pressure and return lines
3" down-pipe, crinkle bent
2.5 crossover, crinkle bent
aluminum cold pipe
black silicone couplers and ss clamps.
Here's the pic of this kit.
and installed.
Mandrel option. 2200.00
Years 99-06
MP70MM turbos,
44mm blow offs,
3" down-pipe aluminized MANDREL BENT
2.5 crossover,aluminized MANDREL BENT
aluminum cold pipe
IF you added the intercooler upgrade your kit will look a lot like this.. pic has lots of extras. use it for referencing the IC only.
Stainless Option. 2500.00
Years 99-06
MP70MM turbos,
44mm blow offs,
3" down-pipe Stainless Steel MANDREL BENT
2.5 crossover,Stainless Steel MANDREL BENT
aluminum cold pipe
IF you added the intercooler upgrade your kit will look a lot like this.. pic has lots of extras. use it for referencing the IC only. and piping will be swapped to stainless steel.
07 inter-cooler kits can be built but at an added cost.
Rick
Standard: 1800.00
Years 99-11 trucks,
MP70MM turbos,
44mm blow offs,
aluminum cold pipe
and installed.
Years 99-06
MP70MM turbos,
44mm blow offs,
aluminum cold pipe
Years 99-06
MP70MM turbos,
44mm blow offs,
aluminum cold pipe
does that intercooler mount up next to the radiator or between the framerails? if its up with the radiator, will it fit with an enlarged trans cooler?
NON intercooled kits fits 99-11. Inter cooler options as priced fit the 99-06 truck.
