Lyscholm Vs MagnaCharger
Old Apr 28, 2006 | 12:21 PM
BlownChevy's Avatar
blownerator
25 Year Member
Default Lyscholm Vs MagnaCharger
Lyscholm 2300 vs Magna Charger MP122H (soon to be released) HP is very close, but take note of the discharge temps. Remember the 2300 is a 2.3L blower and the 122 is a 2.0L blower. This dis-proves the "screw is cooler" Statement made by most of the "screw" Manufactures.
10 lbs boost on a stock 5.3 truck engine with a G2-3 Lingenfelter cam , timming was locked at 26 degrees and VP 103 was used, This test was done just a few weeks ago. As you can see the discharge temps are about 20* cooler on the 122 at 10 pounds of boost.
Old Apr 28, 2006 | 01:40 PM
ranwalk's Avatar
Were both units intercooled?
Old Apr 28, 2006 | 01:59 PM
BigTex's Avatar
What device was used to read temperature for these tests?
Was this a side mount whipple? What were the intake configurations? Did the whipple have its usual 90* TB plenum?
10psi of boost could mean a vastly different CFM variance between the two configurations.
Old Apr 28, 2006 | 02:07 PM
ranwalk's Avatar
Besides the different iat's, the Whipple looks to have made slightly better power. Most likely because its a slightly larger compresor.
Old Apr 28, 2006 | 02:17 PM
BlownChevy's Avatar
blownerator
25 Year Member
All superchargers were tested on the Magnuson Intercooled manifold. The measuring device is the temp probe supplied by Superflow for measuing intake temps. (Type K high resolution thermo couplers)
Old Apr 28, 2006 | 02:20 PM
BlownChevy's Avatar
blownerator
25 Year Member
Correct, however with the lower discharge temps more timing could be added .
This test was preformed to prove or disprove the claims of lower discharge temps.
Old Apr 28, 2006 | 02:28 PM
PSM's Avatar
PSM
any thoughts why the discharge temps seem to ramp up quick on the whipple after 5000 rpms??
Old Apr 28, 2006 | 02:43 PM
ranwalk's Avatar
Good point.
I'd love to see what the new Whipples do. Wonder if they really are better than the Lysholm ones.
Old Apr 28, 2006 | 03:09 PM
moregrip's Avatar
what a rush!
those look to be very close in terms of power output with the nod going to the twin screw under those test parameters; however, it's curious that the screw's discharge temps are considerably higher from about 400hp/4000rpm on up, isn't that where these things SHOULD shine? That MP122 looks to be a very efficient piece and on .3 less liters.
neither of these guys are slouches, that's evident.
Old Apr 28, 2006 | 03:11 PM
BigTex's Avatar
Did magnusson create an adapter plate for the whipple compresor and run a different drive snout, but still use the Radix belt routing and brackets? I for one would like to see a picture.
