Magna Charger Vs Pro Charger
Got some cool information today and I thought you guys would like to see it.
OK here is a test of the Magna Charger 112 VS Procharger D1 at 10 lbs boost on a stock 5.3 truck engine with a G2-3 Lingenfelter cam , timming was locked at 26 degrees and VP 103 was used, This test was done just a few weeks ago. As you can see the HP is the same at the same 10 lbs of boost.
Originally Posted by Richard@WCCH
Very impressive Magnusson torque curve Brian. Big torque bubble in the all important low and mid range rpms. Thank you for posting this info.
Richard
Richard
wait until its tested with some WCCH "special" heads
you probably wont have this info but I will ask any way.
at what rpm did the magna charger reach full boost of 10 psi?
at the rpm that the magna charger made full boost what was the boost from the procharger at the same rpm?
at what rpm did the procharger reach full boost of 10 psi?
at 5000 rpm's I see the magna charger is just past full torque.
at 5000 rpm's what was the psi of the procharger?
were both units intercooled ?
both units where intercooled....the other info is on the charts.
