OK, 551 hp and 647 lbs at 17psi.
Ok, I just got the baseline numbers for my test of the ls1 intake. The numbers here are with the stock intake, on a dynojet. Hp and tq is droping off at 4500rpm. I am running pig rich at 10.0 AFR. (witch means there is more power in the tune, if tuned for 17psi) I just did a run to see how it would do on a dynojet, and to get a baseline for the intake swap. I am still loosing boost, it peaked at 17psi but dropped to 14 during the run. I could not get any dyno time in at synergy to dynotune. It's a two week wait. I will post the dyno sheet as soon as I find my digital camera. Not bad. I will slap on the ls1 intake this week and try to see the difference. I will post both dyno sheets and let you decide if it's worth it. Ok, here is the dyno.
good god!! 551hp and 647tq on a stock 5.3 with 317 heads with ZO6 cam?? Thats nuts!! I cant wait to see what the dyno looks like with the LS1 manifold!! I was hoping to make 650 on the 6.0 and I think that its very possible. Please keep us posted!!
Yeah! I think you are right, It's not the best for longevity. But, I think that is the risk you take when you go HIGH PERFORMANCE. I am surprised that the transmission and clutch is holding. Stock t-56 and the OZ 700 clutch. The trans has 80k miles on it, as per what the guy who sold it to me said. Thanks Guys! I cant wait to see what the ls1 does as well. I think it will just change my AFR, hopefully for the better. I also hope it will bring my hp and tq peaks closer. As well as a higher powerband. I think the hp may be the same, and the tq may lower alittle. Here is to wishfull thinking!
That is awesome man!
I feel a hell of alot better about my estimated HP I had with my STS and 14.5psi and a full tune then
Keep us posted on the intake results and after the tune. I'm really excited to see how it tunrs out since we had a similar setup.
#24
Well the truck is running! But not very good. I hooked everything up and my wideband is showing an extream lean condition. the injectors are not leaking, motor runs smooth untill I give it gas. It sound like a miss. I think I missed something. My vacume is normal! Is it possible to mix up the fuel lines, they both look the same?I have to look at it tomarrow. Wish me luck!
#25
did you check all your wiring and your coil packs. i had the main coil pack harness disconnected once and the truck fired up idles ok but when i gave it gas it would respond so much lol. i would say check all your wiring first ro everything. do you have a way to check your fuel pressure also?
#26
I think you are right! I think I may have something backwards. Fuel lines are right, I may have mix up the wireing. May be the injector conections. I am trying to find time to play with it. But the wife and kid are sick so I have to pitch in alot of time there. Thanks for the info.
#28
Ok! It was a loose injector wire. I Think I lost quite a bit of low end torque, I just drove it around the block. Just alittle boost, it did not feel as stong. I hope as I drive it around alittle more it will get better. I hope it just feels slower but is much faster, like when the I first test drove the 93 camero (auto/lt1). I didn't think it felt fast but it was alot faster than my mustang (5speed,5.0,bolt on's and gears) at the time. That camero kicked my *** everytime, I didn't understand it, it didn't feal that fast. Anyway, I hope it gets better, or looks better on the dyno and track!
#29
Did you use the truck rails and injectors? Did you cut the water pump neck and the alt bracket?
