Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
OK, 551 hp and 647 lbs at 17psi.
Old Mar 20, 2006 | 09:20 PM
TURBO8's Avatar
Default OK, 551 hp and 647 lbs at 17psi.
Ok, I just got the baseline numbers for my test of the ls1 intake. The numbers here are with the stock intake, on a dynojet. Hp and tq is droping off at 4500rpm. I am running pig rich at 10.0 AFR. (witch means there is more power in the tune, if tuned for 17psi) I just did a run to see how it would do on a dynojet, and to get a baseline for the intake swap. I am still loosing boost, it peaked at 17psi but dropped to 14 during the run. I could not get any dyno time in at synergy to dynotune. It's a two week wait. I will post the dyno sheet as soon as I find my digital camera. Not bad. I will slap on the ls1 intake this week and try to see the difference. I will post both dyno sheets and let you decide if it's worth it. Ok, here is the dyno.
Attached Thumbnails OK, 551 hp and 647 lbs at 17psi.-551hp-647tq.jpeg-001.jpg   OK, 551 hp and 647 lbs at 17psi.-seats-006-small-.jpg   OK, 551 hp and 647 lbs at 17psi.-seats-007-small-.jpg
Old Mar 20, 2006 | 09:31 PM
kbracing96's Avatar
Those are some nice number man! Good to know theres some hp still in it too! I'd like to see that dyno sheet. I got a Z06 cam in the little 4.8 and plan on turning it up a bit
Old Mar 20, 2006 | 10:08 PM
greentahoe's Avatar
good god!! 551hp and 647tq on a stock 5.3 with 317 heads with ZO6 cam?? Thats nuts!! I cant wait to see what the dyno looks like with the LS1 manifold!! I was hoping to make 650 on the 6.0 and I think that its very possible. Please keep us posted!!
Old Mar 20, 2006 | 11:00 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I wouldnt expect the lil 5.3 to last long under those conditions but sounds like it is running like a raped ape at the moment.
Old Mar 20, 2006 | 11:17 PM
Dave68RT's Avatar
wow nice truck is that a T56?
nevermind thats kinda dumb question
Old Mar 20, 2006 | 11:57 PM
TURBO8's Avatar
Yeah! I think you are right, It's not the best for longevity. But, I think that is the risk you take when you go HIGH PERFORMANCE. I am surprised that the transmission and clutch is holding. Stock t-56 and the OZ 700 clutch. The trans has 80k miles on it, as per what the guy who sold it to me said. Thanks Guys! I cant wait to see what the ls1 does as well. I think it will just change my AFR, hopefully for the better. I also hope it will bring my hp and tq peaks closer. As well as a higher powerband. I think the hp may be the same, and the tq may lower alittle. Here is to wishfull thinking!
Old Mar 21, 2006 | 12:30 AM
F8L Z71's Avatar
That is awesome man!
I feel a hell of alot better about my estimated HP I had with my STS and 14.5psi and a full tune then
Keep us posted on the intake results and after the tune. I'm really excited to see how it tunrs out since we had a similar setup.
Old Mar 21, 2006 | 12:36 AM
CHarris's Avatar
Very nice numbers!
Old Mar 21, 2006 | 01:36 AM
TurboGibbs's Avatar
Very nice indeed!
Old Mar 21, 2006 | 06:31 AM
bud8fan's Avatar
bad *** numbers dude...
