Who here has done the LS1/LS6 intake manifold swap?
Old Apr 21, 2004 | 03:57 PM
14 Second Truck Club
Default Who here has done the LS1/LS6 intake manifold swap?
What is involved in this swap? Was there any significant gains/losses?
Thanks.
Old Apr 21, 2004 | 04:15 PM
A lot more is involved than I'd be willing to do for not so great gains. Rather put my efforts so something else like cam work or exhaust.
Old Apr 21, 2004 | 04:56 PM
Yelo's Avatar
I'm not so sure why people have such a hard time with this swap.....it took me about hour and a half to complete from start to finish
1. you CAN use the truck rails and injectors......all that is requires is spacers/bushings and longer bolts, the truck crossover looks stupid but works.....custom bent one like I did if you are worried about it
2. the truck water-pump works JUST FINE, cutting the water neck off about 3/4" above the pump and adding a 45* adapter and a short piece of hose was all I needed to make it work
3. EVERYTHING ELSE is a DIRECT SWAP
Old Apr 21, 2004 | 05:03 PM
blacksheep's Avatar
Just like he said works fine, It made noticable gains on my truck.
Old Apr 21, 2004 | 05:13 PM
one03sierra's Avatar
Formerly one92rs
Talking
yelo got any pics ,please.
Old Apr 21, 2004 | 05:21 PM
Well alrighty then. Perhaps you could do a right up and take some pics of what you did? Captured my attention...
Old Apr 21, 2004 | 05:27 PM
Yelo's Avatar
I'll see what I can do.....I'm working alot of hours right now but give me a few days and I'll see if I can't do a write-up on it
as for pics....all I have is the end result, I didn't take any while I was doing the swap because it was so simple....ryan23silverado did this same swap except for the truck injectors and rails, his website has some good pics of the install
Old Apr 21, 2004 | 08:23 PM
Thanks for info guys!
Yelo: which one did you go with, LS1 or LS6? How did it affect your rpm range?
blacksheep: How did it affect your rpm range?
Old Apr 21, 2004 | 08:56 PM
Oh yeah, where could I get one of these for real cheap?
Old Apr 21, 2004 | 10:14 PM
blacksheep's Avatar
The change in RPM range I couldn't tell you(I shift at 6800), but it did pick up 5 mph.
