Rod/Main Bearing?
Old 12-21-2014, 09:28 PM
Hivelocit's Avatar
Default Rod/Main Bearing?
I have a 2004 LQ4 I'm rebuilding and Summit has many different bearing sets and makes to choose from. Question is are all LS Engines Rod/Main Bearings cross compatible through the years from the 4.8-6.0? Only difference would be undersize or oversized correct? Thanks, can't find the answer anywhere!
Old 12-21-2014, 11:29 PM
Hivelocit's Avatar
Anybody?
Old 12-21-2014, 11:35 PM
Vortec350ss's Avatar
Are you literally just lookin for a stock replacement? Stock pistons and all?
Old 12-21-2014, 11:52 PM
Hivelocit's Avatar
Well I'm buying some off here from someone and I was told all LS Rod/Main bearings are interchangeable for the LS engine. So I am just neding a confirmation on this being true? They will be stock undersized bearings as I had the crank turned.
Old 12-22-2014, 08:42 AM
I'm sorry I think I misunderstood what you were lookin to do exactly... I thought you wanted rods and bearings. You only want the bearings. Yes as far as I know they are interchangeable
Old 12-22-2014, 05:07 PM
dirt track racer 81's Avatar
All are interchangeable. The newer block do have different cam bearings.
Old 12-22-2014, 05:29 PM
Hivelocit's Avatar
K Thanks guys! Good to know!
lukn4trbl355
10-21-2015 11:19 PM
sTNT971
09-26-2015 04:22 PM
97_ek
09-23-2015 09:16 PM
Velocity1
09-22-2015 01:32 PM
600 horses
09-10-2015 11:01 AM
Quick Reply: Rod/Main Bearing?
