choppy cam for 5.3
Old 11-04-2010, 04:21 PM
mr mississippi's Avatar
Default choppy cam for 5.3
i have a 5.3 that i wanna cam and install headers. also i don't really want to change the converter but if i have to i will. its a daily driven 2000 yukon i want a real choppy sound lsa 112 or lower but with a good power band for daily driving. was thinking a thumper cam but i've heard different opinions about it. what would be a good cam to use and i will change valve springs to match cam
Old 11-04-2010, 04:29 PM
Nicksilverado's Avatar
check out the sponsers on the right >>>> texas-speed and performance has a lot of cam selections..
Old 11-04-2010, 11:05 PM
PT's Slowest Truck
budhayes3's Avatar
A cam with a real choppy sound will have a lot of overlap and a higher powerband, which will require a higher stalled converter to not be soggy down low. You need to decide which is more important to you, performance and driveability or sound, you can't have it both ways.
Old 11-04-2010, 11:35 PM
formery SilverSleeper1500 (12-06-2011)
Dbyers2's Avatar
I have the thunder racing TR 220 112 lsa in my 5.3 and it sounds sick with longtube Headers, been kicked off the beach 4 times for noise
Old 11-05-2010, 02:34 PM
00Silv4.8's Avatar
^^ 220's sound good, even meaner with LT's. My truck has a 220 in a 4.8 so should lope like crazy, It may be on a 114 for how high my power band is and thru stock manifolds it sounds pretty decent.
Old 11-06-2010, 10:00 AM
Bigschwerm's Avatar
I was thinking of swapping my Vinci Trucker cam ground on a 110 for a TR220 but I'm not sure if the power gain with be worth it or noticeable....
GrooveCityZ71
08-31-2015 12:05 PM
JordanH
08-08-2015 07:59 PM
steves86ta
07-28-2015 10:21 AM
projectnightcrawler
07-19-2015 11:30 PM
06 4.8
07-15-2015 07:17 PM
Quick Reply: choppy cam for 5.3
