7400 Vortec L29 to CNP conversion, reluctor removal and install
Old 03-07-2017, 08:57 AM
legerwn's Avatar
Default 7400 Vortec L29 to CNP conversion, reluctor removal and install
can someone explain how to remove the old reluctor and install the new one?
Special tools needed?
I pulled on it and it didn't move so I'm thinking it may be pressed on.
Thanks Neal
Old 03-11-2017, 05:46 AM
Gadgetized's Avatar
If it's anything like an LS engine you just heat the gear up with a torch and it falls off. On an LS you heat the gear up and it falls on. But you do need a tool to give it the proper clock position when you install it. Can you post a pic?
Old 03-11-2017, 07:45 AM
legerwn's Avatar
Yep, on the vortec it's clocked by the crank keyway and it's sandwiched between the crank shoulder and the balancer. I'll get a picture posted this afternoon when I get home.
thanks Neal
Old 03-11-2017, 06:43 PM
legerwn's Avatar
Well, I taped it with a hammer and it broke free and slid right off.
It is not an interference fit, it just slides on and off.
Pics;
Neal
