NNBS HD conversion
Old 03-26-2012, 02:33 PM
  #31
Rubens09's Avatar
Originally Posted by 07ccz71
I want to do this really bad Thanks for the parts list, but those prices do not work for us Canadians, for some reason the shipping and prices go up and I'm only 45 minutes from the boarder lol.....Those crew cabs look awesome my trucks white so I'm a little partial to the white one but ruben your silver crew looks bad ***
Thanks man it was a long time waiting to get it done but came out good no chips in it either. It's been on for about 2 or 3 months and it's holding up great with this crazy Houston weather we are having
Old 10-20-2012, 08:11 PM
  #32
cel81xtreme's Avatar
Originally Posted by Daniels2386
-2011 HD hood- 20952912 ---- $392.67
-2011 HD bumper w/fog light holes (they call it "bar")- 25883349 ---- $310.54
-2011 HD grille- 20966058 ------ $177.84
-Fog Lamps- (Left side) 25883245 ------ $71.91
-Fog Lamps- (Right side) 25883246 ----- $66.94 Why is 1 side higher than the other?
-2011 Hood trim molding (Grille piece)- 20963700 ---------- $50.48
-2011 Plastic molding (cowling piece that says Allison or duramax or whatever)- Neither the left nor right side came back with a price. Also GMPartsDirect may be a tad cheaper, but I copy + pasted from GMPartsOnline.
Total on prices w/out plastic molding = $1070.38
This is probably a $1500.00 - $1775.00 swap if you add the molding + prep + paint....close?
where can i get the bumper and mounting hardware. I think its time to make the move.
Old 10-24-2012, 03:34 PM
  #33
carbongmc's Avatar
If you can find out if the Chevy and GMC HD bumper brackets are the same, I have 2 sets of GMC HD brackets at my house. Im a pack rat for sure.....Let me know.
Old 10-27-2012, 03:01 PM
  #34
KIFER88's Avatar
i just did mine a month ago. for monting brackets i used the factory frame brackets that were on my 1500 and then drilled the three holes that hold the bumper side of the bracket (which is a 2500) in place up higher in the bumper and slotted the hole in the bracket as well. after doin so i had to cut out a few holes in the face of the factory 1500 frame bracket to give room for the bolt heads from the bumper side of the bracket to be able to fit tight enuf to get correct alignment. hope this sheds some light on your project....
i need to get a pic of mine on here now after the swap they look sharp..
Old 10-21-2013, 02:44 PM
  #35
NemesisC5's Avatar
On my 2011 could I just add the HD grill and HD hood (w/trim) and keep my bumper and end caps? Would there be any gaps at the bottom of the grill where it meets bumper and end caps?
Old 04-08-2014, 03:48 PM
  #36
Registered User
jhlugo's Avatar
Where would i be able to buy all these parts for my truck
Old 04-24-2014, 08:26 PM
  #37
Crashtest496's Avatar
I finished mine up a few months ago, have a few pics of the chevy HD bracket on the thread I had put together. https://www.performancetrucks.net/fo...t-info-525200/
The chevy hd frame brackets are a 1/8" Narrower than the stock 1500 width. The gmc frame is the same in measurement from the chevy.
I found my bumper on craigslist and the rest from ebay and my parts man from dealer, got a really good deal on the hood from lqk, a couple of small minor dent works dent removed.
I did find that the hd bumper fit fine with the stock grille and the hd grille fit fine with the factory bumper. Only thing was the corners was rounded and the bumper was squared looked ok but was noticicable
Old 04-24-2014, 08:34 PM
  #38
Old 04-25-2014, 12:07 AM
  #39
Three6GMC's Avatar
I have done a few HD swaps on the Silverados and Sierras...
Old 04-05-2015, 02:34 AM
  #40
Registered User
Justalittle4.8's Avatar
Where do you get that Bumper w/fog light holes for $310?! aint that too dmmn cheap?
Thanks
Quick Reply: NNBS HD conversion
