Nnbs Arh header Y pipe leaking
Hey guys. I just installed Arh headers, great fitment. But the 2 piece y-pipe where it connects together is leaking. Have you guys had any issues with it leaking or do you use pipe sealant.
Not sure on the ARH but my TSP Y had the same issue. It came with 1" wide band clamps. I ended up ordering a lap joint band clamp from Summit that uses two bolts instead of just one. It was about 3-4" long I would say and covered the whole joint eliminating 99% of the leak. You could also try high temp silicone as well if you like.
zblee
63
06-10-2023 01:25 PM
GXPJAY
02-13-2022 08:15 AM
Suburban2500
07-13-2015 09:57 AM
