Gettting our Truck to Hook Up 101
Old 04-08-2013, 02:12 PM
  #91
I have a gauge for that
Atomic's Avatar
Yea I have straps on mine like that, but I was wondering how the cognitos attached.
Old 04-08-2013, 02:21 PM
  #92
11 Second Hall Moniter
AKlowriderZ71's Avatar
Those are mounts that can be welded to the chassis.
Old 04-08-2013, 02:39 PM
  #93
Denali08's Avatar
Cognitos attach the same way. However, the pic from there web site shows it differently. When I received it, there was nothing to be welded at the end of top bolt.
It has bolt that will need a hole drilled at shock top mount for it. At the bottom, it will bolt to lower shock mount.
Old 04-08-2013, 02:48 PM
  #94
Denali08's Avatar
I corrected the pic in post# 87 by attaching actual pic. So there is nothing to weld in that front strap kit.
Old 04-08-2013, 02:50 PM
  #95
Atomic's Avatar
Ah ok, so same way everyone else does it
Old 04-08-2013, 03:16 PM
  #96
Denali08's Avatar
I just noticed that it doesn't come with any bolts for bolting to the lower shock mount. It says I should bolt the bottom end of the limit strap to the factory lower shock mount.
Parts List:
-(2) Limit Straps.
-(2) CV4, 1/2" x 3/4" clevis/stud bracket
-Hardware package (contains (4)flat washers, (4)jam nuts, (2) 1/2" bolts with washers and nuts.
Old 04-08-2013, 03:20 PM
  #97
Atomic's Avatar
Uses the factory bolt probably.
Old 04-09-2013, 08:29 AM
  #98
slowprocess's Avatar
Since we're on the subject.........somebody explain to me how this truck works. Surely somebody knows whats under it to get it stuck to the ground like that.
HeavyChevy's 9.81 Pass Need2Speed Rental PBIR - YouTube
Old 04-09-2013, 08:30 AM
  #99
nonnieselman's Avatar
4 wheel drive... works good off road and awesome onroad
and a big turbo that comes alive, awesome top end pull!
stealthperf
34
02-14-2016 11:35 AM
wrb002
08-31-2015 12:00 PM
04450r
07-24-2015 01:58 AM
black6spdz
07-16-2015 01:32 AM
jrplz
07-09-2015 12:07 AM
Quick Reply: Gettting our Truck to Hook Up 101
