4L60E... no forward gears. Freshly rebuilt.
Old 10-31-2014, 05:51 PM
10 Second Club
Default 4L60E... no forward gears. Freshly rebuilt.
This is in my father's 67' C10. Transmission is from a 99' T/A, was rebuilt by a reputable builder in the area. It was installed in the truck, but wasn't run right away. The builder is having some major health issues and unable to help. He did however suggest that the assembly grease he uses may have dried up in the valve body. Does that sound reasonable? It has reverse and park. No trouble codes currently.
Old 10-31-2014, 06:07 PM
FFDP's Avatar
Nothing when put in 1st??
Fluid level is correct?
Old 10-31-2014, 06:14 PM
TXsilverado's Avatar
let it warm up and see if the grease will melt down. I doubt that's it, but it's worth a shot.
Old 11-01-2014, 12:40 AM
GMCSIERRA5.3's Avatar
Has it ever moved at all since rebuild? Sounds like sprag is backwords..or a cut lip seal
Old 11-01-2014, 06:55 AM
10 Second Club
Never has had any forward gears, fluid level is perfect. Has been up to operating temp several times lately with the same results every time.
Old 11-02-2014, 01:22 AM
James B.'s Avatar
Is it possible that the converter wasn't seated in the pump? Also, that's an LS-spec trans (300mm converter, etc) so what kind of engine is in the C10?
Old 11-02-2014, 03:57 PM
10 Second Club
It has an LS1 out of a 2000 Z28 in front of it. Converter was seated properly. Wish I knew more about how these transmissions work to properly diagnose what is going on inside of it.
RustyD
05-23-2016 07:04 PM
gmcyukon
10-05-2015 06:20 AM
1989k1500
09-29-2015 10:53 AM
Tuckin15s
09-23-2015 09:35 PM
screaminian47
09-07-2015 08:20 PM
Quick Reply: 4L60E... no forward gears. Freshly rebuilt.
