NNBS returnless pump setup
What he said. I chose to keep it and have found a way to increase its output significantly. Just for reference, I have a walbro 450 in stock bucket, with the stock jet tube filling the bucket, stock filter, rollover valve, etc. I can run it completely empty without starving the pump. No holes drilled in the bucket. I'm running fic 1000cc injectors, 14 lbs of boost on e85 fuel, injector duty cycle never goes above 65% and the fuel pressure it 50-60psi cruising and 70-80psi under full boost all the way to shift point. Stock fuel lines and rails. No check engine lights, run it til the low fuel light comes on, everything appears and works like factory.
So what exactly did you have to mod? Any pics?
anyone ever figure this out???
brandon_6667
13
05-23-2017 12:59 PM
