fuel buckets
Old 03-06-2017, 07:44 PM
rpm-inc's Avatar
Default fuel buckets
I know there are differences between the years. ??99-03, 04-06, 07+?? Are there differences inside those years? For cab and bed configurations, 1500, 2500, 3500, etc.
I have an 04 2500hd regular cab long bed. I want to get a bucket/module to modify and then swap in.
Thanks for the info.
Old 03-06-2017, 08:34 PM
I have a gauge for that
Atomic's Avatar
The years won't line up exactly, but within the same style they are the same.
Old 03-07-2017, 09:18 AM
gearheaddrew's Avatar
The differences come in float wire configuration.
The larger the tank - typically - the longer the float wire.
99-03 was a completely different module from the 04+ design. The tank opening for a 99-03 module is about half the size of a 04+ module.
What are you planning to modify on a stock bucket?
Old 03-08-2017, 06:37 PM
rpm-inc's Avatar
I want to add a walbro 450 on a hobbs switch.
Old 03-08-2017, 08:48 PM
What are you trying to accomplish? supercharger? turbo? nitrous?
TI Automotive / Walbro's parent company has released some drop in units for the GMT900 trucks that contain the 450 pumps and come with the level sender assembly.
Old 03-09-2017, 05:07 AM
rpm-inc's Avatar
For a turbo set up. Got a link?
Old 03-09-2017, 06:36 AM
https://www.holley.com/products/fuel...s/parts/12-954
It is called out as a 255lph but it has the F90000267 pump in.
Old 03-09-2017, 06:39 AM
here is a link to a member who used one on his 2500hd.
https://www.performancetrucks.net/fo...l-done-540302/
Old 03-09-2017, 07:40 PM
rpm-inc's Avatar
Interesting. And expensive. If I were to replace the stock pump with the 450 and hotwired, can the regulator handle it?
Old 03-09-2017, 08:07 PM
Quality components are seldom cheap.
To answer your question it's not likely that the stock regulator will handle the extra flow.
