14 bolt swap into 89 gmc 1500
So if I go out to the pick and pull and I find a posi, 4.10 , gm corporate 14 bolt in an 88 to 98 chevy or gmc 2500 to 3500 truck is it a direct bolt in for my 1500?
Some stuff I read says yes other stuff I read says the 2500 and 3500 trucks were actually 1 to 2 inches wider so the shock mounts and spring perches won't line up.
Any info greatly appreciated. If it's not a bolt in solution I'm just going to pursue a 9inch axel
Shock mounts will line right up regardless. 2wd mounts are a bit lower, but a slightly longer shock, and that too becomes a non-issue.
fillpot
03-01-2016 05:51 AM
