Western CA, AZ, NV, UT, CO, NM, WA, OR, ID, MT, WY, HI, AK
good place for crank relearn
Old Jun 6, 2006 | 05:03 PM
5.3L Bullet's Avatar
Default good place for crank relearn
Does anyone in Tucson or Phoenix do the relearn for free or cheap. I'm in Tucson but wouldnt mind going to Phoenix if i cant get it done here. I've called to a few places in Tucson but sounds like they dont know what they are doing.
Old Jun 6, 2006 | 06:11 PM
BlownChevy's Avatar
blownerator
25 Year Member
You might want to give Charles at Pro Dyno a call, I am not sure what he will charge....but he can do it.
Old Jun 6, 2006 | 06:19 PM
thunder550's Avatar
High on diesel fumes
EFILive says it can do it. I have never tried personally, but if you want to come up I will give it a shot.
Old Jun 6, 2006 | 06:26 PM
dc_justin's Avatar
Hello Dave
It's a snap. The instructions are very easy to follow. If you do it, I recommend setting up a sound and a 1-2 second delay to notify you when to start.
Old Jun 6, 2006 | 06:28 PM
Nick™'s Avatar
yep, just find a member on here with efi live or hp tuners and buy them a 6 pack and I bet you'll have guys jumping to do it for you
Old Jun 6, 2006 | 06:56 PM
thunder550's Avatar
Ok if it's easy then bring your truck on up and we'll figure it out.
Is it weird that I didn't have to do a crank relearn when I swapped engines?
Old Jun 7, 2006 | 10:22 AM
vanillagorilla's Avatar
I can do it too if you need. 6 packs are good!
Old Jun 7, 2006 | 10:26 AM
Nick™'s Avatar
thunder550, it's a good idea to do it even if it doesn't set a code, I've seen not doing it give random knock retard and other minor issues. it only takes a few seconds, longer to start up the laptop than to do it. Just press the start button and gradually rev the motor until it cuts out ~4,000 rpms, shut off and it should be fine on the next start up.
Old Jun 7, 2006 | 01:40 PM
thunder550's Avatar
Cool deal, I'll get 'er done.
Old Jun 7, 2006 | 01:41 PM
thunder550's Avatar
Bitch. Steppin in on my six pack.
