Western CA, AZ, NV, UT, CO, NM, WA, OR, ID, MT, WY, HI, AK
f body's with a ls1
Old Jul 17, 2011 | 03:08 PM
6789olds's Avatar
Default f body's with a ls1
are the ls1 in the 98 trans-am are they good engines ? or was there any problems with this year ? i was looking at maybe getting one for a daily driver . thanks
Old Jul 17, 2011 | 04:37 PM
Eric67's Avatar
No problems the only downfall to the early ls1 fbodys to the latter ones is that the 98 heads don't flow as good and the 98-00 have the EGR system still
The worst thing about the fbodys it the 4l60e is week and the 10 bolt rear ends are week
Old Jul 17, 2011 | 04:55 PM
6789olds's Avatar
cool thanks
Old Jul 18, 2011 | 09:21 PM
Braunbeck's Avatar
Just an FYI, some of the '98 had piston slap issues also.
Old Jul 21, 2011 | 04:27 PM
Eric67's Avatar
Almost every ls1, lm7, lq9, Exc that I ever had as some piston slap when you first start them cold. Just the nature of the motor
Old Jul 21, 2011 | 04:36 PM
98-99 also had weaker rod bolts and the 98's have parameter valve cover bolts
You really want the 01-02 ls1
Old Jul 21, 2011 | 05:09 PM
TX Tahoe Z71's Avatar
98's had the less desirable PCM, 99+ PCM's are better. Don't ask me why, but I remember reading a lot about it back in the day on Tech. Like said above, 01-02 are the ones to get; LS6 manifold, better PCM, bigger injectors (iirc), and some other stuff.
Old Jul 21, 2011 | 05:15 PM
06murder's Avatar
try n keep it 00-02...these are the best ls1 in fox bodys
Old Jul 21, 2011 | 05:26 PM
F-bodies, fox bodies are mustangs
Dawas
Sep 20, 2015 12:00 PM
99bluefirebird
Sep 17, 2015 08:05 PM
FormulaZR
Sep 14, 2015 05:23 PM
Rockrz
Sep 13, 2015 12:22 AM
