Took some logs - WOT and RAFIN
Old 01-25-2010, 06:29 PM
Wearin' da big hat
00ChevyScott's Avatar
Default Took some logs - WOT and RAFIN
Figured I'd post em up and see if any of you more experienced tuners can see anything that needs work or anything like that.
I started by clearing all fuel trims, then did a RAFIN log to about 203 degrees F. Then on the 2nd log, I took it to some back roads and did multiple WOT pulls up to ~100
These were done with EFIlive
File Type: efi
File Type: efi
Old 01-25-2010, 06:35 PM
I have a gauge for that
Atomic's Avatar
RAFIN?
Old 01-25-2010, 06:45 PM
Resident Retard
BlackGMC's Avatar
RAFIN = Running Airflow In Gear
Old 01-25-2010, 06:48 PM
Atomic's Avatar
ah, id just call it idle warm-up and not try to be all fancy with it
Resident Retard
BlackGMC's Avatar
Also since your still running the MAF you need to log cylair_dma....
Wearin' da big hat
Neutral*
I didn't do the in gear one yet corey, I'll probably do that tomorrow if I get a chance. Do you see anything that's out of whack? I haven't logged or retuned this thing in 3 months since we last messed with it.
Old 01-25-2010, 06:49 PM
Wearin' da big hat
I used the two PIDs you sent me a long time ago, for the RAFIG and the LC1 PIDs.
I need to figure out wtf is wrong with my wideband too
Old 01-25-2010, 06:53 PM
Resident Retard
BlackGMC's Avatar
Well either i was smoking crack that day or you mixed up the PIDs.... Your logging a PID for SD... Dyncylair_dma is for SD, cylair_dma is for MAF, it is kinda hard to see what your grams/cyl is doing when you log the wrong one...
Old 01-25-2010, 06:57 PM
Wearin' da big hat
Haha you sent me these PIDs back in October last year I think.
I emailed you the PID I used.
Old 01-25-2010, 06:58 PM
Resident Retard
BlackGMC's Avatar
well then that was when i was in my prime crack smoking stage.
Quick Reply: Took some logs - WOT and RAFIN
