92 bronco full size, possible short in the system?
Old Nov 12, 2011 | 12:03 AM
jik294's Avatar
Default 92 bronco full size, possible short in the system?
so i have a 92 bronco 5.0 5spd that i think there is a short in the system. i'm being told that it could be the wiring harness.
i'll sit there and watch the dash and the gauges will just reset for no reason ever couple of minutes. it'll also run like a$$ when warmed up (i'm thinking it's somewhere in the ignition) and if you shut it off when it's warm you gotta let it cool down in order to start it back up(i've already replaced the ignition module)
i'm really tempted to switch it over from EFI to carb just to get away from this issue.
has anybody had an issue like this before? or does anyone have any ideas on it?
if i do switch to carb what do i need to do to make the switch?
thanks.
Old Nov 12, 2011 | 12:08 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I don't understand what you're trying to explain here. What do you mean when you say the gauges "reset"? Can you be more specific?
Old Nov 12, 2011 | 12:14 AM
jik294's Avatar
when the truck is running the gauges will turn off then come back on for a brief second as if they lost power and then got power back.
Stainless Works
Apr 10, 2016 04:34 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
jrplz
Jul 9, 2015 12:07 AM
