wot tuning with e85
Old Jun 16, 2008 | 07:45 PM
mcfarlnd's Avatar
Un-Registered User
Default wot tuning with e85
i put some e85 in my tank this week and was wondering what would be ideal a/f for it at wot?
Old Jun 16, 2008 | 07:46 PM
BlackGMC's Avatar
Resident Retard
where is the station you went to?
Old Jun 16, 2008 | 07:53 PM
mcfarlnd's Avatar
Un-Registered User
crowley. near burleson at kroger on 731
Old Jun 16, 2008 | 08:11 PM
kbracing96's Avatar
Are you using a WB? And if so, have you reconfigure it to display the right values for the percent of E-85 you have in the tank. I would just leave it configured for gasoline and tune to the same AFR you have been, that won't be the actual AFR you are getting, but it will give you numbers you are used to seeing.
Old Jun 16, 2008 | 10:37 PM
mcfarlnd's Avatar
Un-Registered User
yeah im using a w/b. if i were to tune for gasoline with e-85 ill be running rich correct? just asking cause i really dont plan on keeping e-85 in the tank, i just wanted to try it out as cheap high octane. but i dont want to be lean.
Old Jun 17, 2008 | 12:50 AM
kbracing96's Avatar
Just keep tuning for the AFR on your WB like you are now, it won't actually be lean. WB read stoich (complete combustion of fuel) and convert that to afr. Your WB is configured to convert it to gas afr, even though it will be a mix of gas ethanol. It will actually be richer then its saying, but you will be safe. I know it sounds hard to understand, but research how wb's work and what stoich is and you will understand.
Old Jun 17, 2008 | 01:51 AM
stock48's Avatar
9 Second Truck Club
If your truck is a flex fuel it should automatically compinsate. To kow the optimum afr you need to know the exact % ethanol in the tank.
Old Jun 17, 2008 | 07:47 AM
mcfarlnd's Avatar
Un-Registered User
thats what i thought. but, i was going to try to tune the wot with it. im sure its pretty fat.
Old Jun 17, 2008 | 07:52 AM
mcfarlnd's Avatar
Un-Registered User
i know what stoich is, but what i was asking since gas has a different burn rate and E-85 takes more fuel to a particle of air then what would be an ideal afr to be seen on a w/b for wot. gas is somewhere around 13.1 correct.
Razor
Dec 1, 2015 10:46 AM
06 4.8
Aug 21, 2015 11:33 PM
ss4chad
Aug 15, 2015 02:25 AM
Ls3silverado
Jul 31, 2015 04:22 PM
lxcoupe
Jul 14, 2015 10:14 PM
