It won't connect!
Old Oct 18, 2006 | 07:35 PM
Tan327's Avatar
Default It won't connect!
I'm trying to read a tune out of an 04 LLY Duramax and for some reason it won't connect with the PCM! It keeps telling me to check the cables and turn the ignition off and try again, but it still does nothing. I've noticed in the little PCM selection box it says 98 PCM, 99+ PCM, and Duramax LBZ. There isn't a Duramax LLY selection, could this be the problem? Any help at all is appreciated, I've got to get this figured out ASAP!
Old Oct 18, 2006 | 07:42 PM
LesPaul's Avatar
check you lighter make sure it works...... if not cheack your lighter fuse... your pcm connection is powered by the same line
Old Oct 18, 2006 | 08:01 PM
Wilde Racing's Avatar
How do I change this text
I've had to restart my labtop, Re-cycle the key, and unplug the MPVI interface will the labtop shuts down and restarts. Can you connect to the MPVI?
Old Oct 18, 2006 | 08:27 PM
Tan327's Avatar
Just checked the lighter and it does not work, checking the fuse now.
Old Oct 18, 2006 | 08:29 PM
12sec.5.3's Avatar
Mine does that sometimes too. All I do is unplug the usb cable from the flashscan box and plug it right back in and reconnect. It works everytime.
Old Oct 18, 2006 | 08:53 PM
ridnlow's Avatar
if the lighter doesnt work, the obdii doesnt work.. Thought i fried my buddys obdii port, but the fuse blew because we had the power inverter (running laptop) plugged into cig lighter
Old Oct 18, 2006 | 09:39 PM
Tan327's Avatar
Well turns out the problem was the fuse, how crazy is that? Thanks LesPaul, I owe you one man!
Old Oct 19, 2006 | 10:04 AM
LesPaul's Avatar
glad to hear it worked out for you.... wish someone told me.... i dicked with mine for hours....
dsbodley
Nov 14, 2015 09:46 PM
wickedRCSB
Oct 30, 2015 09:45 PM
nabozny21
Oct 17, 2015 07:47 PM
Wrecker 426
Sep 29, 2015 11:00 PM
old motorhead
Sep 29, 2015 08:22 PM
