WO Converter lockup
Old Mar 22, 2008 | 10:23 PM
03sierraslt's Avatar
Default WO Converter lockup
Who is locking there converter at WO? Where are you setting it to lockup at? What gears are you locking it in? I just realized currently mine doenst ever lock at WO, but with the new converter I believe I should be locking it at some point. I think....
Old Mar 22, 2008 | 10:33 PM
Stoichiometric's Avatar
Lock it in 3rd at the track. I'm not sure if its better to delay the lockup a little after the shift or lock it asap, that is a test and tune item.
Old Mar 22, 2008 | 10:43 PM
Ya that is what I am trying to figure out.
Old Mar 22, 2008 | 11:05 PM
Llaverito's Avatar
I lock it as soon as it shifts into 3rd works great!
Old Mar 22, 2008 | 11:10 PM
MikeGyver's Avatar
Mine is set to never lock in 2nd, and lock at 68 in 3rd, and 87 in 4th at 100%. I am not saying if those are good speeds or not, that is just where they have been since my 1st mail-order tune.
Old Mar 23, 2008 | 09:20 PM
v8
17,16,15,14,13,12,11 Drvr
well my experience with converter lock up is with a stock or small 2800 converter leave it unlocked in all gears, now with a 3000 or higher lock it at 95mph in 3rd gear with 4.10 gear or 10mph after shifting into 3rd gear, with a turbo locking it will help keep load on it and a s/c will bog it down so hope this helps good luck.
Old Mar 25, 2008 | 06:06 PM
sickREDsierra's Avatar
my tuner did a dyno run with mine unlocked, then another run with it locked. then he did a graph overlay to see where the two runs intersected one another, and locked it at that point.... and i believe it was around 100 mph or so...
Old Mar 25, 2008 | 08:28 PM
stock48's Avatar
9 Second Truck Club
With around 600RWHP mine doesn't hold under WOT. I get around 2-300RPM of slip. Thinking about trying A tripple disk precision if the money tree ever starts blooming again.
Old Mar 26, 2008 | 05:30 AM
Thats what mine is, PI 10.5 triple disk.
Old Mar 26, 2008 | 08:25 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Well.......I have been trying to get mine to lock as soon as I completed the 2-3 shift, which according to logs is now occuring.
My 2-3 is ~85mph and lock is commanded at 82mph. Scan shows converter mode lock as i enter 3rd.
I am wondering if my trap speed is down as a result altough the et is lower too?
log from a 12.09 run...
File Type: hpl
