Wiring harness plug removal?
Is there an easy way to remove plugs on our harnesses? I don't know if you need a special tool or what?
I need to replace the gear selector switch plug. The end was melted somehow and the reverse lights won't work. Thanks guys
If you are trying to get the plug out of the backup light switch spray the connector with some carb cleaner to soften the epoxy and then slowly and carefully pull rearward on the plug.
D1SCSS
Jan 25, 2016 10:14 PM
grantpo
Jul 15, 2015 12:21 PM
