wierd spark plug color
Old Dec 22, 2005 | 10:50 PM
TURBHOE's Avatar
Originally Posted by SSlow 4.8
oh okay.. no worries than... sounds good tho. You like the royal purple better than mobil 1?
yes i do i've been using it for about 4 years now i guess in everything i own
Old Dec 23, 2005 | 09:11 AM
LBSBLOWN's Avatar
Can the green tip mean the plug is to HOT and you need a step cooler plug.
I just checked mine, I'm running TR6's and my AFR at WOT is 11.9 to 12.1 on my AEM Wide Band O2 , so I'm not lean but my plugs are green also, I think we need to go a step cooler plug.
Old Dec 23, 2005 | 09:29 AM
TURBHOE's Avatar
i'm running tr55's in mine. i just went out and checked mine again and they aren't green anymore you can see where they were but are not now. but they look ok now. i fattened up my wot and pe some and it ran like a raped ape when i did that. i thought i had added more fuel the other day but then i thought about it and i had lowered that range in the ve table so i bumped it back up to around 100% in those areas so it will give more fuel. and it seem to run real strong. oh and i notice that my stock kr tables are diff than the same year 5.3 tables so should i run like 01 vett ve tables or maybe a gto so that they meat the requirements of the alluminum 5.7??
Old Dec 23, 2005 | 09:43 AM
LBSBLOWN's Avatar
I just did a search for colder plugs and at NGK the only thing I found colder than a TR6 would be an Iridium Plug (TR7IX or a TR8IX).
I running 11.5 psi boost at 11.8 to 12.1 AFR so it appears that the TR6's may not be cold enough.
anybody else running colder plugs than a TR6?
and what plugs are you running?
Old Dec 23, 2005 | 10:31 AM
TURBHOE's Avatar
well i just adjusted my kr tables to one of an 05 cts-v
twake_410
Apr 14, 2016 09:58 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
KleanKustoms
Sep 30, 2015 05:07 PM
