Wideband
Old Feb 1, 2012 | 11:01 AM
custm2500's Avatar
Ph.D. in HUBRIS
Default Wideband
Is this the correct wideband that will work with my V1 EFI live? Just wanted to make sure before I order it.
http://www.ebay.com/itm/Innovate-LC-...item2c62ba20b8
Old Feb 1, 2012 | 11:25 AM
smokeshow's Avatar
Mod with training wheels
I think the question is, are you compatible with EFI Live?
Old Feb 1, 2012 | 11:29 AM
ak2007r6's Avatar
I believe it will. It says it has the analog output which is what i know my tuner used with HP Tuners. As long as your harness that plugs into the computer has the input for the analog wire you should be set.
Old Feb 1, 2012 | 11:34 AM
custm2500's Avatar
Ph.D. in HUBRIS
Yes my cable has an input. Lots of people talk about inovative Widebands but just wanted to make sure this would work.
Thanks.
My compatability will be determined. Justin will be helping atleast at first. Then hopefuly I can get it done from there.
Old Feb 1, 2012 | 12:23 PM
2007chevy5.3l's Avatar
Yup you can serial log or analog with the LC1 on Efilive
Old Feb 1, 2012 | 12:25 PM
ak2007r6's Avatar
Are you sold on the Inovative wideband? I picked up an AEM for my truck and the thing is top notch in quality and was way easy to install.
Might even get one for a little cheaper than the one you are looking at
AEM AIR FUEL DIGITAL WIDEBAND O2 UEGO CONTROLLER GAUGE 6-IN-1 30-4100 FREE SHIP (840879013417) | eBay
Old Feb 1, 2012 | 12:52 PM
BlackGMC's Avatar
Resident Retard
In his top post he has a V1, so he can not serial log.
Old Feb 1, 2012 | 04:43 PM
Oops my bad, good catch Corey
Old Feb 1, 2012 | 07:17 PM
custm2500's Avatar
Ph.D. in HUBRIS
What is serial log?
I can still log with this for my tuning correct? Or is serial logging the only type? If so that means I will have mentaly monitor what my afr is doing? Thanks.
EDIT: After reading an above post again it seems like I can analog log? What is the differance aside from I can ony do one of them. Thanks.
Old Feb 1, 2012 | 10:15 PM
Gadgetized's Avatar
The V2 has a serial port on it (it looks like a phone style plug). That will plug into the LC-1. It will log the same. It is thought that the serial port is easier, and will eliminate any slight error the analog might have. If you check your reading against your NB sensor, you can tell if it is reading properly. Justin can tell you this when you send him a log.
