Why am I getting so much KR?
Old Dec 11, 2006 | 08:19 PM
  #21
dc_justin's Avatar
Hello Dave
Originally Posted by Rhino79
I tried to open the logs with EFI and cant view the logs?????
Right click, Save as, then make sure the file extension is .efi
Old Dec 11, 2006 | 09:13 PM
  #22
RandomHero's Avatar
Originally Posted by Whippled 496
A few things i see that dont make a lot of sense here. Keep in mind I am not a tuner by any means, just learning how to do this stuff so take what i say with a grain of salt, i am sure Justin will chime back in soon. I like to look at logs and try and figure out whats going on.
1st, it seems your LTFTs are on the high side, they seem to be floating around the +9 mark quite a bit. This could indicate a few things from what i understand. Leak in the intake between the MAF and the manifold, or maybe some injector problems?
2nd, you have some wierd fluxuation going on in your MAF readings. In both of your logs, it looks as if you have pegged the throttle (WOT) and are just letting it run up the scale. Well, there seems to be quite a few peaks and valleys in both your MAF (Hz) and MAF (Grams/s) readings. Your TPS is constant at 100% and your RPMs are climbing steady, but your MAF readings seem to go up and down inconsistantly. It would seem that your grams/s and your Hz should be climbing steadily just as your MPH and RPMs climb....but they dont, they dip in spots.
Also, in 2 instances where you came into some KR, your spark advance actually increased (log2 frames 62 - 63) and (log1 frames 204 - 205). maybe something is up with your high/low octane table. Really hard to say for sure without seeing the tune, but like Justin said, if its Jesse's you may want to get permission first. Remember, this is all stuff that looks wierd to ME and may mean nothing, im just a novice at this stuff so i look forward to someone explaining a few of these things to me too.
Still need to change that knock recovery rate table though..
Wow, thanks for the help. Here is another piece of information that is definantly worth adding. Lately, when I start the truck cold it idles down to about 300 rms and almost dies then it comes back up. I've never had this problem until putting my wait4me in. What do y'all think this might be?
Old Dec 11, 2006 | 09:22 PM
  #23
dc_justin's Avatar
Hello Dave
How long have you had the PCM in?
What you'll want to do (initially) is log the RAFIG PIDs.
GM.IAC_LTD_DMA.gps
GM.IAC_STD_DMA.gps
CALC.RAFIG
That'll tell you how much you need to add or remove from your desired airflow table to get it to idle properly. Also, check the timing and desired idle speeds.
And I agree with what Whippled says about your tune, with the exception of the knock recovery. Although I'm different than many, I prefer to let the recovery drag on a bit so long as it will help prevent multiple knock events from occuring.
Do you have a de-screend MAF? If so, I'm afraid you'll need to replace it as the signal is not clear. Otherwise, looks like it could use a cleaning.
Get that MAF fixed up, then address the KR.
Old Dec 12, 2006 | 05:23 AM
  #24
Whippled 496's Avatar
So what do I get....a "C+" or maybe a "B- on my assessment?"
Old Dec 12, 2006 | 05:32 AM
  #25
dewmanshu's Avatar
Moderately Differentiated
B+, that dc_justin guy and his knock recovery passiveness(is that such a word). He's only okay with all that low knock recovery cuz of that California gas.
Old Dec 12, 2006 | 09:27 AM
  #26
RandomHero's Avatar
GM.IAC_LTD_DMA.gps
GM.IAC_STD_DMA.gps
CALC.RAFIG
First of all, i've only had the Tune in my truck for 2 weeks. It has seen about 600 miles on it.
Secondly, no I do not have a descreened MAF, but it has never been cleaned in 2 years so that may be an issue.
As far as my idle problem, it is only for 2-3 seconds before it goes back to the normal 700 rpm idle I have it set at.
I don't have a wideband, just FYi so I may not be able to do all the logs you suggested I do.
Thanks a ton everybody for helping out
Old Dec 12, 2006 | 10:53 AM
  #27
dc_justin's Avatar
Hello Dave
I'm just very knock averse in general. If I've hit a condition that is causing knock to occur, I'd prefer for the timing to be less for a few moments to dissuade that knock event from occuring again, rather than have multiple spikes of KR.
And out here we don't believe in grades. Grades are a form of putting people into classes and all people are equal...
