Who has HP tuners version 2.23?
Old Aug 31, 2015 | 08:46 AM
Preshr's Avatar
Default Who has HP tuners version 2.23?
I can't find version 2.23 on the internets, for obvious reasons. The same reasons that I would like to have it. Can anyone hook me up before HPT finds this page and makes admin take it down?
Thanks.
Old Aug 31, 2015 | 09:19 AM
03sierraslt's Avatar
There is no reason for this post to be taken down.
I have 2.24 and 2.25, why do you specifically want 2.23?
Old Aug 31, 2015 | 10:10 AM
Preshr's Avatar
HPT got rid of the options delete EGR and DPF on the diesel engines and all I have is the latest version. I would like to have the earlier version so I have the ability to put straight exhaust on my truck. I believe 2.23 is the latest version that these options are still available.
Old Aug 31, 2015 | 10:14 AM
Preshr's Avatar
Looks like 2.22 will work also.
Old Aug 31, 2015 | 01:12 PM
It has to be 2.23.410 or there abouts or older to still have DPF Delete. That is the version I use for it. I know my next 2.23 update after that one it was gone. I doubt any version of 2.22 is going to have definitions for some of the later model trucks that 2.23.410 will work on. And i would bet that if you let the more recent 2.24 versions update the firmware on your cable that it will no longer work with the older versions of their software. Just guessing on that but I stopped updating my 2.24 several months ago when they announced it would update the cable firmware because I don't want to risk it not working for 2.23 versions.
Old Aug 31, 2015 | 02:23 PM
Preshr's Avatar
I believe that 2.22 is capable of tuning LMM which is what I am working with. However, my cable is less than a year old so I am probably screwed anyway. Could I PM you an email address and have you send me the version you use just to try?
Old Aug 31, 2015 | 09:51 PM
PM'd.
Old Mar 21, 2016 | 08:07 PM
Blazer1's Avatar
Were you guys able to use the older version of the software (2.23 or 2.22) with a newer cable that has updated firmware? I am in exactly the same situation as Preshr.. Considering buying a new cable from HPTuners but it won't do me any good if it doesn't work with the older software. Thanks.
Old Mar 21, 2016 | 09:02 PM
Since HPT is heavily promoting their 3.0 software that updates the firmware to where the only 2.24 it will work with is 2.24.1165 - 2.24.1170 or there abouts. Nothing older works with the new firmware.
Old Mar 21, 2016 | 09:05 PM
Blazer1's Avatar
I suspected that may be the case. Thanks for confirming!
