when tuning in SD
Old Oct 29, 2005 | 06:38 PM
dewmanshu's Avatar
Moderately Differentiated
Default when tuning in SD
Nobody ever mentions resetting the fuel trims. Should I do this before I start..I'll be tuning with WB so unfortunately I won't be using 02sierraz71_5.3 great write up, but nevertheless...I don't remember him mentioning it either. I read the article from Chevy High Performance and they mention resetting the trims.
thnx,
dewey
Old Oct 30, 2005 | 12:12 PM
02sierraz71_5.3's Avatar
its in there
if you disable the lt's you wont need to hit the button everytime just once.
Old Oct 30, 2005 | 12:15 PM
dewmanshu's Avatar
Originally Posted by 02sierraz71_5.3
its in there
Yeh, I am sorry...I jumped the gun...I didn't recall reading it and then after I posted my question went and read your write up and some others again. Thanks 02sierraz!
Old Oct 30, 2005 | 05:43 PM
no prob let me know if I can help out
Old Oct 30, 2005 | 06:04 PM
dc_justin's Avatar
Hello Dave
You have a 2 bar MAP sensor, right? Otherwise, SD tuning in boost will be tricky...
Old Oct 30, 2005 | 06:57 PM
dewmanshu's Avatar
holy **** no. I have the 3.0 pulley as well...as soon as give any kind of good throttle it goes into boost.
Short of paying for a 2bar sensor and paying HPT an exuberate amount of cash to get 2 bar, what should I do as to be able to tune this gas hog? Unhook the bypass valve so it doesn't go into boost? But then it would be out of whack when I hook it back up right? ugh.
Old Oct 31, 2005 | 08:12 AM
dc_justin's Avatar
Hello Dave
You could always buy a 2 bar sensor, PN 12580698, and then scale down your VE table (and all MAP related tables). You'll lose some resolution, but gain the ability to tune in boost. Won't cost you anything with HPT.
Old Oct 31, 2005 | 02:08 PM
dewmanshu's Avatar
I went ahead and did a run with wideband yesterday. drove for about an hour. never hit the 4K column of the ve table. Implemented the changes and there is a huge difference in responsiveness and power. I am having fuel pressure issues up top...pressure starts to drop at WOT...but other than that it seems to getting pretty tight. Seems to me the only "iffy" part with boost (FI) is in the transition stage of boost and no boost...some where around the 3000rpm area. I have the 1 bar setup so I can mess with the multiplier some to see if that will ease the transition.
Old Oct 31, 2005 | 04:34 PM
CHarris's Avatar
If you have a boost gauge you can drive around hitting as many cells as possible without going into the 1psi range. You can tune all the way to zero vacuum and that should get you buy fine. After all... once you get into boost you are into PE fueling anyway. Tune your PE and you're all set.
Old Oct 31, 2005 | 05:50 PM
dewmanshu's Avatar
that's what i've been doing. i've logged and "pasted" twice now...lt's are no higher than -4 and I am pretty confident I get those down just a tad more. She's getting a snappy throttle now...pretty cool. WB is defintely cool.
