wheatley tuning help
my mom threw away the instructions to my pcm so i dont know how to use it once i install it. i know its something like turn on for 11min and off for 30 sec or something can somebody tell how to do this so my truck can relearn the new tune....
Robert
Robert
https://www.performancetrucks.net/fo...sslock+relearn
or you could always just call Wheatley
You need to reset the security code in VATS.
1. Turn the key on to start the engine, then release the key to the ON position.
2. The security light will flash for 10 minutes then go off.
3. Turn key OFF after security light has stopped flashing.
4. Leave the key off for 30 seconds or so. Not sure if you have to wait but it won't hurt. Repeat steps 1 to 3 for 2 more times for a total of 3 attempts. The vehicle should start on the 4th attempt. This procedure takes at least 30 minutes. The battery should be fully charged and deliver more than 10 volts.
These instructions should have been included with your PCM from Nelson!
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
oharajo
Jul 18, 2015 09:24 PM
