Wait4me Review!
Old Aug 20, 2005 | 12:58 PM
4SHONGO's Avatar
Default Wait4me Review!
Just put mine in this morning and it seems to pull alittle harder. not a big difference in shift firmness. Tow/Haul does make a difference. Seems better than my HPIII, I heard it will get better with more driving. Hope so! Anybody got this tune and the SES light did not come on? I was told that i should be getting the relearn code but I am getting nothing and I have driven over 50 miles already. Any suggestions? The Clinton manual says that when ever you change out the PCM you should have it done.
Old Aug 20, 2005 | 01:10 PM
goshawk23's Avatar
Truck addict
i have read where you should do it no matter if you get the ses light or not.
Old Aug 20, 2005 | 01:39 PM
TURBHOE's Avatar
ok what about when you swap a motor out??
Old Aug 20, 2005 | 02:10 PM
goshawk23's Avatar
Truck addict
i haven't heard of doing it for swapping motors out. With as many people around here doing engine swaps i am sure there would be some expert advice on it though
Old Aug 20, 2005 | 07:31 PM
ReedyCreekRacin's Avatar
ive got a PCMforless tune, didnt feel like waiting until Christmas for Jesse to get me a tune...no offense, he's just a busy man, and i hate waiting on anything.
the only thing i had to do was the security relearn. the truck wouldnt start...well it would light off, but then die immediately.
as far as any other relearn i dont know. mine runs great, hauls ***, even though its setting a code for the MAP sensor, lol.
CHIP
Old Aug 20, 2005 | 07:49 PM
04BlackGmc's Avatar
10 Second Club
Jesse said to get it done when putting a new pcm in, even if you dont get a light.
Old Aug 20, 2005 | 08:38 PM
gobblergetter's Avatar
I will be taking mine next week to get the crank relearn. I did not get a light.
Old Aug 20, 2005 | 09:46 PM
4SHONGO's Avatar
I called Jesse and he told me to get it done anyway. Called the dealer and they said $75. For 5 minutes of work, I couldn't believe it! Anyone in the Gulfport, MS area with a hook up?
Old Aug 21, 2005 | 07:59 AM
bart cox's Avatar
Needs a case relearn, it's the same as if you just swapped the PCM.
The PCM needs to know the relationship of the crankshaft to the cam via the crankshaft pick-up sensor.
if you replace the timing chain, timing gears it will also need to be redone.
Old Aug 21, 2005 | 01:12 PM
TURBHOE's Avatar
isn't that the one where you have to rev your eng to fuel cut and back down if it is shouldn't i wait till the break in is good before i do that or will it be ok?
