upgrading to two bar SD tune VE Table issues
Old Nov 8, 2015 | 07:35 PM
marlboroman71818's Avatar
Default upgrading to two bar SD tune VE Table issues
Need help, I'm updating to the 2bar OS and the VE table is automatically populated from my old tune into the 2bar os but the map pressure and VE #s do not match up with my old tune correctly due to the axis values being different increments 10 instead of 5. So do I trust the automatically transferred values or do I need to copy every row of values at the 10 increments and copy and paste to the corresponding rows in the 2bar tune and then copy the 105kpa row on the old tune and put it in the 210kpa value of the 2bar and multiply by 1.25 and interpolate between verticle bounds?
Old Nov 8, 2015 | 08:05 PM
smokeshow's Avatar
Mod with training wheels
Copy row by row of the old table into the new table and then extrapolate accordingly into the new unpopulated area. 1.25 won't necessarily work...you'll need to increase the values gradually and in line with the rate at which they increased in the 0-105kpa section of the table. This is all just an estimation, as the boost section of the VE will need actual calibration.
Old Nov 9, 2015 | 01:41 PM
thanks smokeshow, another question can I use the iat from the maf ro do I have to put a gm open loop iat in the intake charge pipe? if so how do you cancel out the maf?
Old Nov 9, 2015 | 01:56 PM
Atomic's Avatar
I have a gauge for that
You can do either (IAT sensor), but generally people install a new sensor and get rid of the MAF all together. You set the dynamic rpm limit (or something like that), to its highest value and zero out the maf table for good measure to fail the maf.
As jake said, copy the rows you have and interpolate between. To fill the rest of the table extrapolate from the first half. Start working into higher pressures slowly so you aren't in a bad spot under a lot of power. You should see a pattern develop pretty quickly.
Old Nov 9, 2015 | 02:03 PM
do I zero out the maf calibration table? dynamic rpm limit?
bigsapper
Nov 9, 2015 07:14 AM
97aztecgt
Nov 3, 2015 09:55 AM
MikeD.
Nov 2, 2015 07:01 PM
GMJim
Oct 24, 2015 12:04 AM
JL ws-6
Oct 19, 2015 04:18 PM
