tuning for meth
Old Jun 13, 2007 | 09:20 PM
Stoichiometric's Avatar
My PE shows 14:1 almost everywhere and 25* of timing. My eyes are also glued to the Alky LED and wideband gauge. Truck runs great, actual AFR is 11.5.
Old Jun 13, 2007 | 09:22 PM
kbracing96's Avatar
I personally do it with VE, but I'm 2bar SD. I want my commanded AFR to match my WB all the time. I keep that sucker full all the time too, if my WW light comes on (hardly ever happens) I won't hardly touch the gas, lol.
Old Jun 13, 2007 | 11:15 PM
Wilde Racing's Avatar
How do I change this text
I have the STS boost controler 6 low 12 high, I set my B.E up to run 11.8 up to about 6 psi the I command almost a 14.X air fuel after 145 kpa (above my low setting on the boost controler.) So at low boost I'm safe with-out meth, High setting is with meth comming on around 2 psi of boost. The down fall of the whole set-up is I'm a bit rich for the first 2-5 psi of boost in the high setting.
Old Jun 14, 2007 | 11:00 AM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by KySilverado
Yeah pull from PE.... and DON'T run out of Meth.
And from Dewey's statement a little known fact I think. Your outputs from the MPVI don't work unless you have your laptop plugged up and scanning.
I was talking about the controller for the wideband, not the MPVI. My wideband controller has an output for my nitrous and meth.
Old Jun 14, 2007 | 11:59 AM
wkdivr's Avatar
What make wideband do you have?
Old Jun 14, 2007 | 12:44 PM
Holty's Avatar
Notorious BIG
he has a dynojet
Old Jun 14, 2007 | 12:57 PM
dewmanshu's Avatar
Originally Posted by Holty
he has a dynojet
Silveradorst07
Dec 31, 2015 12:04 AM
Ls3silverado
Jul 31, 2015 04:22 PM
tim wellington
Jul 31, 2015 03:28 PM
Jetn3
Jul 21, 2015 01:44 PM
