tuning for meth
Old Jun 13, 2007 | 08:20 AM
wkdivr's Avatar
Default tuning for meth
I got the Alkycontrol kit in and running well, now.....I just have to tune for it. I need to lean my wot afr out to make better use of the addition of meth. Which way would be the better to "pull fuel"? Lean out my pe eq; maf, or ve table?
Old Jun 13, 2007 | 06:26 PM
wkdivr's Avatar
ttttt
Old Jun 13, 2007 | 07:32 PM
dewmanshu's Avatar
Moderately Differentiated
you are 1bar right...still got the MAF going. Then use the PE table IMO.
If your into wiring and messing with stuff and you have an output on your controller on your wideband, get a relay and tell the wideband controller to allow a resistor to get inline with your IAT sensor to tell the pcm the IAT is the highest temp and pull massive amounts of timing(IAT Advance table). Set your controller up to do that at what ever AFR you want protection at. I don't know what resistor would do that, but I am sure the info is somewhere on tech or hpt. (I babble all of this cuz people always want to know how to protect themselves if the meth fails or runs out. Obviously...don't run out.)
Old Jun 13, 2007 | 08:01 PM
KySilverado's Avatar
Yeah pull from PE.... and DON'T run out of Meth.
And from Dewey's statement a little known fact I think. Your outputs from the MPVI don't work unless you have your laptop plugged up and scanning.
Old Jun 13, 2007 | 08:04 PM
wkdivr's Avatar
Yeah.....still 1 bar system. I was trying to put together a meth tune, but I just couldn't bring myself to put the numbers in the PE table to make it the correct AFR at wot. I just couldn't create a system that's THAT lean.. I know it needs to be to be right with the meth....but I just couldn't!
Holty's Avatar
Notorious BIG
We already discussed this earlier on the phone!
Old Jun 13, 2007 | 08:09 PM
wkdivr's Avatar
Yeah, I know. Got rained on, tonight, so I gotta do SOMETHING!
Old Jun 13, 2007 | 08:16 PM
In my case I pulled somewhere around 25% need to work on lower load levels.... laptop is dead and waiting on another. Yeah its scary. Trust your wideband.
Old Jun 13, 2007 | 08:25 PM
wkdivr's Avatar
I was a-thinkin it needs to be at least 20%, if not more. I think I'll do some more street testing before Fri night!
Old Jun 13, 2007 | 09:00 PM
Holty's Avatar
Notorious BIG
you crack me up, LOL.......JUST DO IT!
