tuning help
okay well the problem i am having is the truck will not idle and roll at the same time it will give throttle up to about 15mph and jus stay there. I know it has to do with the stall converter but was just wandering what tables to change to get this fixed. i know the throttle cracker tables have to do with this but that hasnt changed anything
no i dont have a scan of it my buddy does but were trying to work it out and yeah as soon as i let off the break it wont just idle and roll it will pull throttle like im pressing the gas but im not and will hang at about 10
If I am reading right what you are describing sounds like you just have a bit too much idle airflow. But without a log and or tune that's the best I can say based on your description.
I second that 03klugss. Read krambo's tuning write up here https://www.performancetrucks.net/fo...tricks-373848/ . I followed this after I did my cam swap and it worked pretty darned good.
So basically, you're truck feels like its in cruise control at 15 mph, correct?
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
oharajo
Jul 18, 2015 09:24 PM
