Tuning for Gas mileage
Originally Posted by dirt_track_racer_81
go speed denisty and lean it out to 15.6 at cruise..thats what ive done to my truck..did it to dozerdans old truck also..he went from around 17 stock and put the cam and speed denisty tune in and he got around 22
Originally Posted by DozerDan
i prolly have no idea what i'm talking about but, i'd max timing and run 91 or whatever...don't the computers pull timing when a lower octane is detected to "prevent" detonation? pulled timing means less performance/mileage right?
Changing the VE, or commanded fuel x rpm x map(?) in EFILive, won't do you any good in MAF OR SD mode if you're in closed loop. Fuel trims will just compensate to keep ya at 14.7 AFR. You will need to be in open loop to really make a difference. There may be a few other ways, but I don't like talking about MPG in public forums. Just wanted to make a point that there is a difference between MAF/SD and OL/CL.
Originally Posted by onebadrubi
Why do you say you dont like talking about MPG in public forums?
DC justin what would you recommend to get optimal gas mileage?
Other gains can be made by adjusting the torque converter apply settings as well as potentially adjusting your part throttle shift points.
Originally Posted by dc_justin
Correct. I was referring to his implied usage of the semi-closed loop feature of COS3/5.
Some methods would be questionable by certain authorities...
I use HP Tuners, so I don't know what the EFILive numbers mean.
Ah. Well, in that case, I'll fill you in a bit. What is referred to in the HPT realm as the OLFA table has been re-configured with EFILive to act as a more versatile commanded fuel table (in similar format to the VE table). With closed loop disabled, any point in the new OLFA table that is commanded at 14.7:1 will drop into closed loop, and any other point remains in open. Allows for some creative fueling techniques.
So in HPT then you would need to drop the MAF and go SD then to accomplish the same thing via commanded fuel, right?
