tuners drilling the throttle body blade
Old May 12, 2012 | 12:50 PM
  #21
TXsilverado's Avatar
lol, allen gives you an explanation, then asks for a chance to fix the problem and you call him butt hurt? wow. good luck getting the issue fixed. i agree with throttle cracker and will throw in the possibility of a vacuum leak causing this.
Old May 12, 2012 | 01:27 PM
  #22
tarinitup's Avatar
9 Second Truck Club
I've rode this train before with Nelson performance. I got about 10 retunes until I stopped blaming the tune and found the real problem. A loose rocker on one cylinder was killing power. A tune can't fix mechanical issues.
Old May 12, 2012 | 01:44 PM
  #23
redsilv's Avatar
i couldve took his exclamation mark out of context.
sorry if i miss took your reply farm truk
ray is fixin another ecm to send out so im still hopeful
txsilv. i dont nut swing. I beleive there is more in the tune but
me and Ray believe its hard to pin point areas without a scan cable
and i know i can be a picky s.o.b
I am changing plugs from ngk tr5 to the ngk iridiumlx
and yes the #7 plug has a crack down the side
and im hoping this will help the backfire/pop noise at 4,5k rpm at gear change
im double checking all the basics that i know of before i go to change the
valve springs to rule out valve float (currently ls6 blue springs)
or taking the injectors out to clean them
It didnt do this with the 5.3 ecm
Old May 12, 2012 | 02:46 PM
  #24
FarmTruc's Avatar
Performance Trucks Sponsor
Originally Posted by redsilv
farm truk
youre getting all butt hurt
and thats not the intention from me
i havent heard of anyone drilling the throttle blade in quit some time
Ray was very nice on the phone. We both agree that its hard to fix
issues with a mail order tune. I do feel the tuned ecm is comparable to the 5.3
stock tune running this set up. wide open throttle versus wide open throttle.
All i am trying to get at is getting this idle issue and maybe some back fire/pop
noise coming from this tuned ecm i installed. going all over the net trying to
read as much as i can. Im replacing the plugs for the hell of it. less than 900 miles on this engine. Im doing all that i can do( mechanical wise ) to get
my drivability they way i like it. I believe with what i have and 216/220 small
cam, a stock like drivability is not too much to ask.
With you coming on here and getting all festered with some drivabilty concern i have is nuts
I am open to Ray fixing what we discussed through nelson performance.
ive read damn good things about nelson performance for years.
lmao, no i'm not, there's just more to tuning and modifying than you realize. And I actually care about my name and product, so I feel I should explain the situation and open your eyes to other possibilities.
It's just a little hard to swallow when you call the shop and Ray spends a while on the phone with you trying to figure things out and at the end of the conversation he thinks you're in agreement with a solution; then a post like this comes up.
And to clarify, it was suggested that you MAY have to drill the throttle body in order to get your truck to idle IF we put the idle values back to stock and idle rpm back to stock.
IF your truck was idling just fine before the tune, with a cam, then your throttle body definitely has something different about it than the normal/typical throttle body; meaning it's allowing more air to flow and idle decent.
I could go into why drilling the throttle body is perfectly ok, but that's an entirely different subject.
btw guys, it's not the throttle cracker doing it, that is untouched, if the truck is "pulling" with no throttle applied, I know what change is causing this, but adding one small value to this table shouldn't be causing the issue, but it is, so I'll put it back to stock. Just one of the fun things trying to tune for many different variables.
Didn't you just find a cracked plug?
That could very well be the popping you're hearing. Be sure to post up the results when you find it.
That cam and stock drivability isn't too much to ask; it's just that we have seen way more tuned pcm's and have a very good understanding on what can cause issues. I never claim my tunes to be perfect and won't pass up a chance to send out another tune to fix something, but I won't just because the customer asks, there has to be some sort of process.
If I were to do this, we'd be sending out pcm's "to fix issues" everyday!
And guess what, 99% of the time it's install or mechanical causing the problem.
As far as "it didn't do that with the stock ecm" it's hard to explain, but I understand the rule of , last person to touch it.
Just keep in mind, your mods are very easy to tune for, they don't come anywhere close to what we've sent out, so if there's an issue with the truck, keep an open mind.
Old May 12, 2012 | 04:04 PM
  #25
chevrolade's Avatar
Quit being a woose and remove all that torque management
Old May 12, 2012 | 04:50 PM
  #26
redsilv's Avatar
alright farmtruk i appreciate your understanding.
if you put all the idle values back to stock. What is the difference of me running the 5.3 ecm? I just want the thing to idle better
900rpm at first start then eventually settling around 650rpm just seems a little strong. its 80 degrees outside
Me and Ray are in agreement about trying to lower the idle some and increase the torque management. We also agree that its better to have a
datalog type tune for long distance relationships.
Im sure i have an easy set up to tune for. Maybe just not in the custom mail order type tune. the shipping would add up.
Ray sounded like he could help me out and is sending another ecm
I couldnt talk much since i still have laryngitis, but i tried
Before i go hacking a hole in my throttle body i would like to think
a good tuner using HP tuners could adjust that idle before that attempt was
made.
And no one comments about me getting beat by a toyota camry?
I was embarrased lol
this thread is supposed to be about tuners still recommending the drilling of the throttle body
So i guess this is a common practice with cams 216/220 or bigger in a 6.0
Even with HP Tuners?
I seiously havent heard of drilling the throttle blade in awhile
Old May 12, 2012 | 04:53 PM
  #27
redsilv's Avatar
yes yes he is !
Ray said he would just remove it all in the tow haul mode
i did estimate my transmissions survival for about a year.
i did put in a B&M tranny cooler
Old May 12, 2012 | 05:01 PM
  #28
Atomic's Avatar
I have a gauge for that
About the camry thing....there are trucks on this forum that stomp corvettes/vipers/lambos/etc. Obviously these trucks arent stock, but how do you think those owners feel?
  #29
you have way too many posts on a performance oriented website to ask such a noob question
Old May 12, 2012 | 05:22 PM
  #30
ak2007r6's Avatar
That's the best thing about making a truck go fast. If you win against some high HP sports car it just adds insult to injury to the owner. If you loose well it's not to bad.. you lost to a high HP sports car LOL
LOL
