Tunercat
Originally Posted by zippy
you can change the w.o.t. a/f ratio, what more would you want to change?
I know I can change the PE mode fuel multiplier but I have no idea if its to lean or not.
Being able to make changes, doesnt mean you SHOULD mae that change. I will wait for my wideband.
peace
Hog
I read your post incorrect, sorry about that. I thought you posted that you couldn't change your a/f ratio. I see that you meant if you can't because you aren't sure where to put it. I highly recomend using the wideband also. Calculate the p.e table to where it should be and tune the V.E to where you get the right number on the wideband.
Originally Posted by leochevy2001
you should ask charlie to go with you to the track and maybe do some fine tuning.
Well, I still need to get by there for him to run it with his scanner to see what everything looks like, and probably make a few changes there. But yeah, I eventually want to get him out there with me at the track.
Curtis,just let me know when you can get down there and I am in man,we will see what is goin on.I will make a few psses with mine while I am there.LOL It has been to long since I have.
I use TunerCAT on an L31 Vortec running 9psi with a 2-Bar MAP sensor and 36# injectors. The factory PCM runs everything but the transmission.
I tuned this engine WITHOUT a wideband O2 unit. It's not easy to do it this way but it is possible if you have the patience to understand how the engine responds to your tuning.
Right now, from a dead stop, throttle response and power are so good I can get SMOKE from the tires just punching it. That's in a 6000-pound Tahoe with 285's on it.
...all made possible by TunerCAT.
peace
Hog
scuzz
May 2, 2006 02:23 PM
Silent Thunder
Jan 30, 2006 01:07 AM
lifted99GMC
Jul 17, 2005 10:12 AM
