Tuner question
What year Tahoe is this?
Ive done 87/93 octane tunes with a switch on the 99-02 Trucks with a COS5 EFI Live tune. It uses the "nitrous retard" settings to pull timing for the 87 octane.
The other easy way is to just get a holley Terminator x max and you can do whatever your heart desires with that. E85, 87, 89, 91, or 93 with a switch.
One of those things that's possible, but not recommended. Most of the time will be fine but there are some scenarios where sustained load under low spark will push EGT to dangerous levels. Think melted exhaust valves, etc. Your mileage may vary.
Originally Posted by FFDP
...t also doesn't go to the exact value in the low octane table either, it use a knock learn factor that will interpolate between the 2 values to help bring knock away...
If you change the OS to the "SD Enhanced" version you get the high/low octane table functionality back. You also lose that pesky secondary VE table. I'm running the 1 Bar SD Enhanced OS in my truck (P01).
Juggernaut
24
Mar 28, 2006 05:02 PM
408 Stepside 01
Sep 1, 2003 11:07 PM
