Tune Problem MAYBE???
Old Mar 13, 2011 | 10:48 AM
bad72blazerct's Avatar
i checked the blue side (which is the side i pluged my electric fans into pin 42 or w/e the nelson instructions said too) and all the connections look good.
Old Mar 13, 2011 | 03:55 PM
I know it sounds stupid but did you hook all the grounds up? I forgot one on my swap and I thought I had a whole bunch of electrical problems. Hooked up the ground and it was good to go.
Old Mar 13, 2011 | 07:00 PM
Wilde Racing's Avatar
How do I change this text
That is a good point too, although it seams strange it only affects one cylinder, I would expect a bank. but non-the-less electrical does strange things when it's left to find it's own ground...
Old Mar 14, 2011 | 03:40 PM
ya im pretty sure all my grounds are connected the cab to the motor the batter to the motor harnesses to the motor about 4 grounds or so all together. im hopen i didnt fry the computer because now i can even pull a code with the code reader i got. and everythings acting all crazy like the lights wont turn off. i think u burnt up one of them relays (grey lil boxes) under the hood in that box. should i go get new ones cause i switched them all around and its still the same thing so that dosnt seem like the answer. im thinking the worse and i fried the comp. the fan dosent even come on when the keys on anymore. weird started friday and sat. but sunday it just wouldnt fire.
Old Mar 14, 2011 | 04:00 PM
alright she finally fired. the grounds on the rear of the motor were lose. "DUMBASS ME" anyways still no number 6 Cyl.
Old Mar 16, 2011 | 08:29 PM
Figured it out whats was wrong with the #6. During disassemble of the blown motor. someone pulled one of the wires out of the injector plug on #6. so i soldered a new plug in off an extra harness i had.
Old Mar 18, 2011 | 06:19 PM
alright everythings with the engine is good. the tune is fine but i only made 251 hp and 253Torque dose this seam right?. Also they said my Converts holding me back? and maybe my stock one would be better? And where is the computer for the tranni, because im certain they didnt flash that and i think that might be my problem, so if someone could through me a bone to where that is and who i could send it too that would be awsome thanks
ferrellrooster
Mar 6, 2025 03:22 PM
mr03silverado
Jun 26, 2016 06:05 AM
shawn96gmc
May 17, 2016 04:15 PM
pittman
Jan 19, 2016 07:06 AM
lxcoupe
Jul 14, 2015 10:14 PM
