truck wont start.need help!
Old Apr 23, 2010 | 03:38 PM
highroller02's Avatar
Default truck wont start.need help!
so I just swapped out trans and converter,I took off the starter but didnt unhook the battery.as I was unbolting the power and ground wires the wrench made contact with them and made some sparks,I didnt think anything of it but now when I go to start the truck it makes a buzzing sound and just clicks when I turn it over.Could I have fried the pcm?
Old Apr 23, 2010 | 03:41 PM
GMCtrk's Avatar
sounds more like your fried the starter.
Old Apr 23, 2010 | 03:53 PM
pasadenaman's Avatar
yup, go get it rebuilt
Old Apr 23, 2010 | 03:57 PM
ok I will try that but why is there a buzzing coming from the fuse panel when I turn the key on and all the lights on the dash flicker?
Old Apr 23, 2010 | 04:11 PM
LowBlack99's Avatar
Have you checked the fuses? Is the starter installed correctly and not in a bind? Is the battery dead?
Old Apr 23, 2010 | 04:27 PM
Unbolt the starter and place it on a cinder block and turn the key..... See of it engages or if its stuck.
Old Apr 23, 2010 | 04:30 PM
ok thank you guys i will try and all these things and let you know.
Old Apr 23, 2010 | 06:25 PM
ok I fixed it.unhooked positive battery cable,hooked it up and started right up.lesson learned always check connections first,thank you guys for your help.
Old May 9, 2010 | 11:17 AM
brandon6.0's Avatar
hey man the same thing happined to me a while back. Check the man big 40 amp crank fuse under the hood that was my problem hope this helps.
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
