truck shuts down randomly
We are going to update some ETC tables today for the ls2 tb, and im hopeful that cures it.
I'm using the LS2 90mm with a conversion harness from katech engine. Im going to swap in my westers tune to make sure its not mechanical.
Every now and then I'll be at a red light, I give it a little throttle and let off, then the truck idles real low and it shuts down. same thing happens when I pull into my driveway. It has an incline, I have to rev it to about 2300 to get it to creep up the driveway and as soon as I let off it shuts down. Any ideas why its doing this?
Adding those small diameter TC are similar to adding a light weight fly wheel on a manual car...
It sounds like the tune to me... That Circle D 4c converter is small and lite weight, which causes the idle to be really really touchy.... I would make sure you have B4349 (ETC Throttle Area Conversion) set accordingly for the 90mm TB. Then i would take a long look at your desired airflow and Throttle follower tables... I bet if you added say 5% to desired airflow it would help... After that you really need to take a look at the throttle follower and throttle follower decay settings, decrease the decay settings so it comes down slower....
I also happened to check battery voltage and it was sitting at 13.2v at idle, and between 13.2-13.4 while driving. It seems low, but is of unknown significance at this time given no obvious electrical symptoms.
Good post, we're thinking similarly...I've already played with those parameters in the manner you've suggested to no avail. I'm just going to go ahead and dial in the desired airflow correctly based on logged parameters (STIT, LTIT, etc.). I also have a feeling that the fact the TB is ported and polished is wreaking some havoc on things. This isn't the standard 87mm truck TB, it's an LS2 90mm, so it's similar to the c5 vette system and swap.
