Trouble Codes from supercharged silverado
Old Mar 29, 2012 | 09:04 AM
nonnieselman's Avatar
Do you have a wideband?
Old Apr 14, 2012 | 05:47 AM
jbancs's Avatar
Originally Posted by david8399
Only 2 bulletins I could find that mentioned all three codes. Unless p0300 is unrelated to lean codes.
I'll have to look more into that second bulletin you posted. I checked the intake manifold gasket with carb cleaner, and it doesn't appear to be leaking. I'm going to check my harnesses, and should have my new plugs and wires coming in this weekend, so hopefully I can get those changed out. I honestly have been so busy I haven't even had the chance to pull any of my plugs to check them out.
No, I don't have a wideband. I am currently working on a console for my truck at work that will house an ipad2, and was looking into dash command which supposedly reports my AFR as well as a bunch of other engine parameters.
Old Apr 14, 2012 | 07:57 AM
CalEditor@PCMCalibrators's Avatar
FormerVendor
How many ECU's does this truck have?
Does this truck use 16 injectors?
Old Apr 14, 2012 | 10:20 PM
they usually have only 2 piggyback injectors on the intake elbow
Old Apr 15, 2012 | 07:32 AM
jbancs's Avatar
I have the factory 8 injectors plus 2 extra injectors on the intake just before the manifold. IT has some accessory electronics ,not 100% sure of the function of them as It was done before I bought the truck and no install manual or paperwork was given to me at all. I can tell you the electronics are tapped into the PCM, but thats about it. I am waiting to hear back from whipple regarding what the electronics control, or at the very least installation instructions or a manual.
Old Apr 15, 2012 | 12:15 PM
I actually live in Fresno and worked at whipple for a bit back in 98-99 the piggyback ecu just drives the injectors and depending what ecu was refrenced off boost.
I say ditch all the whipple electronics get some larger injectors and a custom tune
Old Apr 15, 2012 | 02:35 PM
jbancs's Avatar
Awesome, I assumed thats all it did, but I'd rather read it, or hear it from an informed source. I plan to eliminate the electronics, and get the injectors as soon as time and money permit. Also, I'd like to know if I'll see any performance gains from the injectors and tune. I'm happy with how it drives now (minus the huge delay from torque management), but more power never hurts.
Old Apr 20, 2012 | 03:46 PM
jbancs's Avatar
Man, it just keeps piling on. Started the truck today, and low oil alert was on. Check it, and oil isn't even showing up on the dip stick. Which is weird, because I have no oils spots below my car, and it doesn't smoke at all. Now I'm interested to get it up on a lift, and see whats going on.
Old Apr 20, 2012 | 04:01 PM
Add 2qts of oil and then crank it..
My truck use to do that a few times.. i unhooked the PCV when i went turbo and never had the problem again till i hooked the pcv back up.
Old Apr 20, 2012 | 05:10 PM
jbancs's Avatar
Thanks, I added 2 quarts before heading to work today, and I'm going to be changing my oil in tuesday.
thunder550
Oct 8, 2015 04:53 PM
chevyl33
Aug 24, 2015 08:21 AM
lsxperformance
Aug 2, 2015 10:08 AM
lo&sloSierra
Jul 24, 2015 07:03 PM
GreyChevy
Jul 7, 2015 08:57 PM
