Trans shift points
Old Oct 20, 2006 | 09:46 PM
Bowtie70SS's Avatar
Default Trans shift points
Went to the track tonight...rean a 13.47 not real happy. Part of the problem is my shift points. I was aiming for 5500 but ended up at 6100 and 5900. My question is: Does the trans shift at the comanded mph or RPM? From what I have been seeing it is the MPH as long as the RPM is reached. I am using HPtuners. Thanks
Dave
Old Oct 20, 2006 | 10:35 PM
Rhino79's Avatar
9 Second Club
Both have to be met. Set MPH lower than the RPM and you should be good to go!
Old Oct 21, 2006 | 07:50 AM
Bowtie70SS's Avatar
thanks
Old Oct 21, 2006 | 08:32 AM
dewmanshu's Avatar
Moderately Differentiated
oooooor, just zero out the MPH. It should shift at the commanded rpm always unless there are other issues going on.
Old Oct 21, 2006 | 08:30 PM
DrX's Avatar
DrX
Could just be the TC slip. Try starting with a commanded of 5000 RPM and bump it up a little at a time until it actually shifts at 5500.
Old Oct 21, 2006 | 08:41 PM
1slowsilverado's Avatar
Old Oct 21, 2006 | 08:45 PM
Bowtie70SS's Avatar
If I zero out the MPH tables it will only shift at comanded MPH for a WOT shift right? Now that I think about it I could do that for TOW/HAUL (performance shift). That may be a better idea for me as it is my daily driver right now. Thanks...I didn't think of that before. That's why I love these message boards
Dave
Old Oct 24, 2006 | 11:12 PM
nonnieselman's Avatar
Dave
I think you got something wrong there...
If you zero out the MPH table... it will shift at the commanded RPM, because the MPH is alway met.
Old Oct 25, 2006 | 12:33 AM
Wheatley's Avatar
Truck Sponsor
Both values have to be met
Old Oct 25, 2006 | 08:50 AM
dewmanshu's Avatar
exactly. If WOT MPH is zero that condition is met instantly. No maybe, no kind of. Once rpm is hit, then it shifts. Give or take a few rpm.
