TPS will not read 100%, only reading 60% (3.0V) at WOT
Time2Kill Did you Flash over the original tune when the trans set up changed to a 4L80E???
Did you use a factory tune or a segment swap for a 4L80E, or are you using a 4L60e Tune with the relay method???
MASS seller approved
The customer is ready to rip the 6.0L out and drop in a carbbed 350. We spent all weekend going thru the harness and trying different things.
We currently have the entire engine harness off the car. The ONLY thing connected is Power to the PCM, Pin 1/40 on both connectors to battery negative, and the TPS sensor. Every other Sensor/connector is disconnected. It still wont read over 65%. I am TOTALLY baffled as to what the problem could be. The PCM and Throttle body both read fine on every other vehicle I swap them to.
Using my DMM, I get the exact same voltage reading (2.8 to 3.2v depending on the TPS sensor) at the TPS sensor that the PCM reads when at WOT.
I may have had the 4/5 switched around as to where they are connected. Shouldn't matter though as it sounds like you have it all tied together with the battery.
Make sure that you do not have a DBW OS as many 12212156 vehicles were DBW.....Avs, Corvettes, trucks with traction control.
Also doesn't explain why the PCM and Throttle body both read fine when I swap them to any other vehicle.
gaps
Oct 15, 2015 02:53 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
